Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,680 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
I posted that I was working on this some time ago, and have hae enough forward progress to post a few pictures.
Please note this is not a complete top only a first part off a temporary mold. There's still some tweeking we will be doing on this to get the part a better fit. Here's the summary of progress- We have the tooling for the top portion almost finalized and will be making some adjustments. We are acitvely machining the mounts for the roof so that it will attach with adjustement that can be made in seconds to assure a correct fit. I had noticed on tyhe few Sarasota tops that the substructure appeared to have been repaired as it was pulling the roof too tight. I'm working on a custom box for shipping and storage with a soft foam liner. It will be able to ship Fedex without hitting the second overcharge tier (shipping should be about $60 across the US, and will make a nice storage box for the roof when not in use. The big key here is the mounting substructure. We aer making a semi ridgid frame that will allow for the OEM seals to be used on the rear and sides. This means it should seal as good as the factory roof. We are on track for out budget for this project and the initial offering will be less than $600. Part of the equation is how many will want one. These should be ready for production to begin in 8 weeks if all stays on track. I will not accept any deposits until I have the prototype completed and tested for awhile. I will be posting more on the prototype in abotu 3 weeks, and it will give us an idea of any things we want to tweek before production. Attached thumbnail(s) ![]() ![]() |
jim_hoyland |
Get that VIN ? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,333 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California ![]() ![]() |
A box for storage is a good idea. It need a confy home when not in use... (IMG:style_emoticons/default/smile.gif) The biggest issue I had was the fitment along the leading edge. It didn't snug in just right and the wind generated noice was scary.
And...Saratoga Top or Sarasota Top ???? Attached image(s) ![]() |
JeffBowlsby |
914 Wiring Harnesses ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,573 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None ![]() ![]() |
Lo-Fi Version | Time is now: 24th June 2024 - 11:26 PM |
