TorqueJunkie |
Newbie ![]() Group: Members Posts: 48 Joined: 25-May 10 From: Baltimore, MD Member No.: 11,760 Region Association: None ![]() |
I am in the process of rebuilding my 2.4 engine with 2.2S pistons, S cams, and am going to install TWM individual throttle bodies. I am looking around for some fuel and ignition systems for this engine. I have looked at most of the ones out there, but not sure what works best. On some of the other forums, there is a guy running the Megasquirt(latest version) with good results. Another guy is using Electromitive. I have everything except for the control module. What do you guys use on the flat 6 engines? I do not want to spend a ton of money either. I want something reliable. I hated my carbs.
Randal |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 ![]() |
If you want a system that works, call Matt Lowrance up in Reno (775) 331-4366. He put together the Motec unit on our 2.7 race motor. Matt has done so many of these he has all the fuel maps dialed in, which saves a ton of money BTW I'm running the same TB's as yours on two of my race engines, one with Motec and one with Link. |
Lo-Fi Version | Time is now: 1st July 2024 - 04:10 AM |
