Gigamight |
Member ![]() ![]() Group: Members Posts: 220 Joined: 8-June 09 From: Near Akron, Ohio Member No.: 10,454 Region Association: Middle East ![]() |
I have a guy that is selling a 96 Legacy L. It has a bad diff and bad tires, so he is selling it cheap or it goes for scrap. Would this be a consideration for an engine swap? My research tells me the engine is an EJ25D, which makes around 150 hp, does that sound right?
strawman |
Senior Member ![]() ![]() ![]() Group: Members Posts: 881 Joined: 25-January 08 From: Los Osos, CA Member No.: 8,624 Region Association: Central California ![]() ![]() |
I have a guy that is selling a 96 Legacy L. It has a bad diff and bad tires, so he is selling it cheap or it goes for scrap. Would this be a consideration for an engine swap? My research tells me the engine is an EJ25D, which makes around 150 hp, does that sound right? Since it is a Legacy L, it has a 2.2 liter engine (EJ22). Probably not worth converting your teener with this engine -- unless you're only doing it for mock-up purposes. It came from the factory with only 135hp. Only the 1996-98 Legacy GT & Legacy Outback came with the EJ25D engine -- and those early EJ25D engines had poor head gaskets from the factory. The updated gaskets will usually cure the problem if the car hasn't been overheated too badly; if overheated badly, the engine/head surface can be warped and need surfacing to ensure a good seal. The transmission (assuming it is a 5-sp manual) can be converted to 2wd using the Bremar kit, but that still isn't worth the $400 unless it has VERY low miles. |
Lo-Fi Version | Time is now: 29th June 2024 - 02:22 AM |
