mipstien |
Member ![]() ![]() Group: Members Posts: 261 Joined: 6-April 10 From: Maryville, TN Member No.: 11,576 Region Association: South East States ![]() |
i couldn't find any information on how to adjust or replace the side mirror and i didn't wanna just start unscrewing it incase those screws had bolts on the back and i lost those in the door panel when they fell.
do you just unscrew or do you have to take the panel off? mirror doesn't adjust because its rusted or too tight. |
914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,920 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
I recommend putting some PB Blaster on the nut and letting it soak a little bit. If you get in a hurry, the pot metal has been known to break leaving the mirror useless. You can also take the plastic trim(AA has new ones if you break it)off the mirror and remove the glass. Remove plastic liner and spray the pivot nut.
windforfun |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,884 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None ![]() |
I recommend putting some PB Blaster on the nut and letting it soak a little bit. If you get in a hurry, the pot metal has been known to break leaving the mirror useless. You can also take the plastic trim(AA has new ones if you break it)off the mirror and remove the glass. Remove plastic liner and spray the pivot nut. (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) |
Lo-Fi Version | Time is now: 25th June 2024 - 08:25 PM |
