jaxdream |
Senior Member ![]() ![]() ![]() Group: Members Posts: 974 Joined: 8-July 08 From: North Central Tennessee Member No.: 9,270 Region Association: South East States ![]() |
Got a patch job project to do , I've seen in the restoration threads where McMark had a similar patch project , just looking for some advice on the gap size between the two pieces of sheet metal ( cut a section out of a scraped car (IMG:style_emoticons/default/sawzall-smiley.gif) ) . This is my first time to do any body panel welding , got .024 wire on mig , voltage/amperage set on lowest setting (IMG:style_emoticons/default/welder.gif) , hasn't burned through so far on other pieces I've welded in , just want some ideas about gap size , butted up together , a tiny gap between the two ,or maybe a certain distance apart. Thanks for any replies as I do not want to screw it up rrreeeaall bad (IMG:style_emoticons/default/screwy.gif) that I can't grind it out.
Jack / Jaxdream |
jaxdream |
Yep it's real mig ( 75% Argon / 25% CO2 ) and got one of them copper spoons from Harbor Freight a while back , 230 volt Lincoln 130T with a good sized coil of 10-2 grounded ( solid )as an extention cord of sorts to reduce the voltage and doin a great job at that. Just wanted some idea of gap size that is usual practice, some of the little things sometimes goes unmention , and I, the same as most have that half zymers also and don't really expect every little thing to be mention in a thread , that's why I ask , the only stupid question is usually the one not asked. Thanks guys !!!!! (IMG:style_emoticons/default/welder.gif) (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/pray.gif)
Jack / Jaxdream |
Lo-Fi Version | Time is now: 26th June 2024 - 10:06 AM |
