Welding Back Panel, The one between the engine and interior |
jaxdream |
Jul 10 2010, 03:08 PM
Senior Member Group: Members Posts: 974 Joined: 8-July 08 From: North Central Tennessee Member No.: 9,270 Region Association: South East States |
Got a patch job project to do , I've seen in the restoration threads where McMark had a similar patch project , just looking for some advice on the gap size between the two pieces of sheet metal ( cut a section out of a scraped car (IMG:style_emoticons/default/sawzall-smiley.gif) ) . This is my first time to do any body panel welding , got .024 wire on mig , voltage/amperage set on lowest setting (IMG:style_emoticons/default/welder.gif) , hasn't burned through so far on other pieces I've welded in , just want some ideas about gap size , butted up together , a tiny gap between the two ,or maybe a certain distance apart. Thanks for any replies as I do not want to screw it up rrreeeaall bad (IMG:style_emoticons/default/screwy.gif) that I can't grind it out.
Jack / Jaxdream |
McMark |
Jul 10 2010, 05:57 PM
The gap will end up being whatever it is, but not huge or it's just a PITA to weld in. You want some gap because as the welds shrink the gap will disappear.
Also, I've recently had MUCH better results from welding slowly around the perimeter of the patch and not jumping around from place to place. What I discovered was that if I used 8 spot welds to hold the whole patch in place, then the heat/shrink from welding would cause slight buckling and warping because the piece couldn't move. By welding along the cut line, the warping isn't 'trapped' and can work itself out as you go. Kinda hard to explain, but it's really worked well for me. |
Lo-Fi Version | Time is now: 26th June 2024 - 10:15 AM |
