> Fuel Pump wont run off relay board...
D1A3
post Jul 17 2010, 06:30 PM
Gruppe Neun Vierzehn Südosten
Car died a few weeks ago while driving it and I think I know what is causing it...
Turns out, my fuel pump was not getting power. I temporarily rigged up the pump to run off my driving light relay and the car runs great. I traced the harness power wire (black/red stripe) back all the way to the relay board and could not find any break/melting or anything suspect.
I found in the Haynes Manual that the fuel pump relay should have voltage at 86 and ground at 85. Guess what? I checked and have voltage at 86, but NO ground at 85. The manual says in this case to check the "main relay." What the heck is that? It references the "fuel pump relay" in other places uniquely, so wondering what a "main relay" is on our cars.
Also, mentions that there could be an open circuit causing the ground to fail. What should I check?
The relay being used is known to be good, so any ideas or am I looking at replacing the relay board?
Thanks everyone!
D1A3
post Jul 17 2010, 09:26 PM
Larry,
Checked the grounds that are just on the passenger side of the air intake and they all are grounded well. Is there another spot Pin85 could get it's ground from? I'm really at a loss here...
- Lo-Fi Version Time is now: 27th December 2024 - 07:42 PM
