Replaced my ignition switch (again). Will it solve my start problem?, PLUS I awoke the seat buzzer! |
orthobiz |
Jul 20 2010, 06:52 PM
Senior Member Group: Members Posts: 1,757 Joined: 8-January 07 From: Cadillac, Michigan Member No.: 7,438 Region Association: Upper MidWest |
When I got my 74 1.8 three years ago, it had a new aftermarket ignition switch that went bad immediately. I replaced it with another aftermarket switch but last summer it occasionally would not start, hot or cold. Most recently, I jiggled the key in order to get it to start so I assumed it was the switch again.
So today I replaced the switch with an OEM (Switch Pics in the Parts Vault). But the old switch looked fine. Couldn't detect any cracks, maybe there's internal damage? I had once read about some subtle differences in the switches but could not detect any. Anyone know if the switch can fail and look good externally? This is the fourth switch in the car, including the original, so I'm getting suspicious something else might be wrong. So I put it together and it starts, but the seat buzzer began to go wild whenever I turned the switch. I went back into the garage later and it stopped! Brad Mayeur had worked on it before I got it and disabled it for me. Any thoughts appreciated. I want the car more reliable; I've only been able to take short jaunts where I don't have to stop! Paul |
Tom |
Jul 21 2010, 06:27 AM
Advanced Member Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
I haven't had to do this yet, hence the question. Is the connector that fits to the switch a one piece connector? You may have a questionable contact in the connector itself. Wiggling gives you contact sometimes. Maybe check that the next time you have it off.
Tom |
Lo-Fi Version | Time is now: 27th December 2024 - 04:04 AM |
