gary gartner |
i know more than a newbie---way less than a guru ![]() ![]() Group: Members Posts: 239 Joined: 16-December 04 From: Valencia, Ca Member No.: 3,294 Region Association: Southern California ![]() |
been thinking about a 3rd brake light for a while now found a 10 lamp unit at http://www.commandelectronics.com/ mdl 003-74r and good price at $29.99 brakes on, virtually dissapears when off ![]() |
Nürburg Nomad |
914Rubber.com! ![]() ![]() Group: Members Posts: 296 Joined: 30-March 10 From: Buckeye State Member No.: 11,536 Region Association: Upper MidWest ![]() |
Hey fellow teeners... I have a reputation on other forums for resurecting old threads so why stop with my 914! (IMG:style_emoticons/default/biggrin.gif)
After a little research in this thread and this one here: http://www.914world.com/bbs2/index.php?showtopic=82636 I've decided to notch my roll bar trim for a third LED brake light of which I already have two on hand! The unit I have is removed from an undisclosed 2010 GM automobile, is super low profile and has 16 red LEDs with a white lens that is molded/cast to project the light rather than just act as a plastic cover as you see with many of the aftermarket LED lights. So my primary question is exactly what color are the brake light wires that I'll need to splice into; where are they located; and does anyone have a photo or two?! Additionally, I was throwing around the idea of notching the bottom side of the roll bar pad and installing the light there since it would be a 100% clean installation if it were flush with the pad and no one would ever notice; problem is the angle of the outside rollbar would make it that most other drivers (minus fellow teeners & small British cars!) wouldn't notice the brake light either! So I've progressed to cutting up a few 914 parts in favor of safety and visability. (IMG:style_emoticons/default/biggrin.gif) I also figure the white plastic housing will blend in better with the chrome trim than a red third brake light... (although my car is red isn't it?!) so we shall see, my only concern beyond simply finding the brake light wires is how much modifying of the actual rollbar/sheetmetal will be needed underneath the trim but I'm happy so long as I can retain 100% structural integrity even if it looks a little rough since it'll all be covered. Cut first ask questions later right! (IMG:style_emoticons/default/smile.gif) Thanks for anyones help and I'd appreciate a photo of the brake light wire location in the cab if it all possible... the interior is 100% out again at the moment so everything is accessible! |
Lo-Fi Version | Time is now: 24th June 2024 - 07:08 AM |
