william1764 |
Member ![]() ![]() Group: Members Posts: 252 Joined: 11-May 10 From: maryland Member No.: 11,717 Region Association: MidAtlantic Region ![]() |
mechanic is saying that he needs to remove carbs to investigate/fix backfire issue (bad). He believes carb(s) are dumping fuel which is cause of the problem- maybe float stuck or something? There is a heavy fuel smell after running the car...heavy! How many labor hours should I expect for removal, tear down and rebuild of carbs?
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
Am I understanding you right? The ORIGINAL type fuel pump is still on the car? THERE'S a fire waiting to happen. Let's talk more about that, in detail, before you even consider what the backfiring issues are.
The Cap'n |
VaccaRabite |
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,470 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region ![]() |
Am I understanding you right? The ORIGINAL type fuel pump is still on the car? THERE'S a fire waiting to happen. Let's talk more about that, in detail, before you even consider what the backfiring issues are. The Cap'n Wow. I missed that in the first post. The good rotary fuel pump for carbs is short money. You really don't want 30+ psi in the fuel lines if you are running carbs, even with a regulator in line. I agree with CK. replace the fuel pump sooner then later. Zach |
Lo-Fi Version | Time is now: 20th June 2024 - 05:29 AM |
