> Longs Reinforcement Questions, I don't understand the different kits or options yet
Corkus
post Jul 27 2010, 12:01 PM
Please tell me about the different ways to reinforce the longs on the 914. My car is on the rack and it is time to reinforce this area and things are moving too fast for me to keep up. (IMG:style_emoticons/default/blink.gif)
I have seen the Engman Inner Long Reinforcement kit and the Tangerine Racing Door Sills kit. I think I saw a third kit that reinforced the footwells at the same time as the longs but I can't find that kit again.
I'm confused about the different kits, the terms that describe the longs and the different ways to reinforce this part of the car.
Please clue me in if you know. I'm not even sure what the difference is between "Longs" and "Inner Longs", if there is any. So, you can assume I know nothing here.
Any help is appreciated. Thanks all.
Elliot Cannon
post Jul 27 2010, 11:38 PM
Group: Retired Members
Go with the Engman kit. When you do, drill the holes bigger. (I drilled mine out to 5/8 inch). Makes for a stronger bond.
bugsy0
post Jul 28 2010, 09:20 AM
QUOTE(Elliot Cannon @ Jul 27 2010, 11:38 PM) *
I like the idea of larger holes - stronger bond for sure. What do you coat the steel with on the mating surfaces of the original long and the new layer? I wonder about moisture between the two layers of steel causing problems.
cstone12
post Jul 29 2010, 11:32 AM
QUOTE(bugsy0 @ Jul 28 2010, 11:20 AM) *
I would like to know the answer to this too, anyone?
nsyr
post Jul 29 2010, 12:40 PM
Because I Can
QUOTE(cstone12 @ Jul 29 2010, 01:32 PM) *
weldable primer
example: http://search.eastwood.com/search?w=weldab...Q&ts=custom
Corkus   Longs Reinforcement Questions   Jul 27 2010, 12:01 PM
McMark   The part you linked to for Tangerine Racing Door S...   Jul 27 2010, 12:07 PM
Corkus   Thanks Mark. So when people talk about strengthen...   Jul 27 2010, 01:02 PM
Root_Werks   The weakest area of the long is about were the E-b...   Jul 27 2010, 01:10 PM
Grelber   I have the Brad Mayeur (914ltd) outer long reinfor...   Jul 27 2010, 02:57 PM
Corkus   OK, so now I'm getting somewhere. These are in...   Jul 27 2010, 10:25 PM
siverson   > I'm thinking of going with both the Engma...   Jul 27 2010, 10:36 PM
Elliot Cannon   Go with the Engman kit. When you do, drill the ho...   Jul 27 2010, 11:38 PM
bugsy0   Go with the Engman kit. When you do, drill the h...   Jul 28 2010, 09:20 AM
cstone12   Go with the Engman kit. When you do, drill the ...   Jul 29 2010, 11:32 AM
Vacca Rabite   [quote name='bugsy0' post='1348993' date='Jul 28 ...   Jul 29 2010, 12:38 PM
nsyr   [quote name='bugsy0' post='1348993' date='Jul 28 ...   Jul 29 2010, 12:40 PM
Bartlett 914   I am sure the Engman kit is very good but the Brad...   Jul 28 2010, 09:30 AM
Justinp71   I am sure the Engman kit is very good but the Bra...   Aug 10 2010, 10:32 PM
9146986   Brad Mayeur's kit reinforces the outer suspens...   Jul 28 2010, 11:56 AM
charliew   I know this is about stiffening kits but hopefully...   Aug 10 2010, 06:12 PM
d914   throw tagerine racing back into the picture w its ...   Aug 10 2010, 08:45 PM
RobW   Doesn't it all depend on what you use it for, ...   Aug 10 2010, 09:13 PM
cstone12   What about the ClamShells? Are those a good optio...   Aug 10 2010, 09:29 PM
peteyd   Restoration design also has a outer longitudinal r...   Aug 11 2010, 10:46 AM
JmuRiz   Has anyone actually done both the Brad Meyeur and ...   Aug 11 2010, 12:26 PM
wreglesworth   Hi, I need to do something with my longitudinals a...   Oct 31 2010, 11:30 PM
Andyrew   We need to see the condition of your longs now.. M...   Oct 31 2010, 11:43 PM
sean_v8_914   I did a car with both for a customer. both at the ...   Nov 1 2010, 12:11 AM
Racer Chris   I can't stand the way the Brad Mayeur pieces t...   Nov 1 2010, 08:10 AM
McMark   More info to add to the debate. Look at how deep/...   Nov 4 2010, 05:31 PM
Racer Chris   Look at how deep/wide the inner C section is comp...   Nov 4 2010, 07:23 PM
mepstein   IMO, the ever popular "GT stiffening kit...   Nov 4 2010, 05:51 PM
Racer Chris   Chris - I'm dropping a 3.2 into my car and ad...   Nov 4 2010, 07:34 PM
iamchappy   I put both kits, inner and outer into my car and r...   Nov 4 2010, 06:48 PM
JmuRiz   What needs reinforcing on the suspension console? ...   Nov 4 2010, 08:16 PM
- Lo-Fi Version Time is now: 31st October 2024 - 09:30 PM
