914zim |
Still pretty clueless... ![]() ![]() Group: Members Posts: 221 Joined: 29-July 03 From: New Berlin, WI Member No.: 962 ![]() |
Guys:
OK, I posted on this a while back and got some replies, and I tried to connect them like was suggested, but it didn't work. Maybe I connected them wrong, but I want to make sure I don't fry another part by just trying different connections. I think I need to describe what I have better to get the correct answer. Please bear with me... I have 3 wires coming from my power antenna. 1 is the fat black antenna signal wire (I have this connected). 2 is a thin blue with white tracer. 3 is a thin blue with red tracer. I assume the antenna is grounded where it's mounted to the car. One of the thin wires brings the antenna up and the other brings it down. It makes sense to me that the up wire should be connected to the keyed 12V, so it goes up when the key is turned. Then where does the down wire connect to? I think I remember someone suggesting the remote wire from the amp connecting to the up wire and then both to keyed 12V, but I'm not sure. Can someone please tell me exactly how to connect this thing? I bought a new amp and am planning on some quality 914 time tonight, so hopefully, I can stop bugging you guys about this and get to my clutch pedal issue... Thanks! Andy... (IMG:style_emoticons/default/smile.gif) |
914ghost |
BOB ![]() ![]() Group: Members Posts: 406 Joined: 25-November 03 From: Wenatchee Washington Member No.: 1,387 ![]() |
Andy-
you sure you have a really good ground for the antenna? sometimes theyre mounted in plastic bushings and the antenna body doesnt ground real good. Kinds of sounds like the antenna is trying to ground thru the stereo? (IMG:style_emoticons/default/huh.gif) The BMW and Mercedes power antennas have a separate ground. I think Karl kinda sounds right though- and I've installed them like that- Red/Blue= constant hot (it pulls antenna down) Blue/White=To stereo-blue/white usually and find out a way to ground it separately. -Bob O |
Lo-Fi Version | Time is now: 26th June 2024 - 03:39 AM |
