VaccaRabite |
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,475 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region ![]() |
I am interested in teaching myself how to weld with gas. O2 Accetiline, not MIG gas.
I have a mig welder that I am sort of competent with. Is there benefit to welding with gas over MIG, or am I going to find that if I buy the tank set up, I'll never use it over MIG. Zach |
charliew |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,363 Joined: 31-July 07 From: Crawford, TX. Member No.: 7,958 ![]() |
Brazing and silver soldering has it's place in fabbing on some things that require low heat.
A lot of things used to be cut with track cutters, they were torches set up on a track to cut long cuts of almost any shape but mostly straight. The edge can be used as it is, if it is done correctly but by hand it takes a lot of practice to not have slag on the back side. Thicker metal can be cut cleaner than thinner metals. The tip must be clean so cutting rusty or coated metals will not be as clean of a cut as good clean metal. Before you buy check out a henrob they are really neat. |
Lo-Fi Version | Time is now: 25th June 2024 - 11:24 PM |
