> The Pine-Sol carburetor cleaning thread, You can have clean carbs with that fresh pine scent!
Mark Henry
post Aug 1 2010, 09:02 PM
that's what I do!
With the release bearing exploding in my '67 bus, taking out the pressure plate I decided now was the time to clean and service my Weber 42 DCNF's...of course I got carried away and had to clean my /6 40 IDA's as well. I've been reading on the internet (and I've heard mention of it here) about using Pine-Sol cleaner to clean carbs, so I felt i'd document my job for this site.
Pro's: it's very cheap and most important it cleans like a champ!. (IMG:style_emoticons/default/smilie_pokal.gif)
It's amazing how well it works in all the nooks and crannies.
Although it's slightly caustic it's no where near as nasty as most carb cleaning chemicals and it doesn't seem to hurt rubber parts like diaphragms.
Nice fresh pine scent .
Big safety plus it's Nonflammable!
Con's: It does seem to react with cadmium plating, it doesn't seem to bother the Weber plated parts too much, but my Gene Berg DCNF stacks really reacted to it.
Leaves a film on brass parts, remove them or you have to polish them afterwards, but it does not harm them.
It smell's like pine, real strong, in fact it smells like the janitors room. If you have an attached garage I'd do it outside.
You will get it on you and you will also smell Pine-Sol fresh, wear the gloves and some old clothes.
Loses it's "oomph" after about 3 days, I got 3 carbs done.
You must fully immerse the parts or it can leave a scum line.
You really need a compressor to blow out the passages when done.
No real rocket science here, I got the Pine-Sol and mixed it 2 parts Pine Sol to 1 part water. I used 4 liters (quarts) of pinesol. I found that this plastic waste basket was just the perfect size for the IDA /6 carbs. I had a handful of latex gloves, a couple of toothbrushes, some tools, compressor,
a table and a bag of rags.
You must throughly rinse with water and dry (blow out) the carbs when done.
Mark Henry
post Aug 1 2010, 09:30 PM
that's what I do!
Although the 40's don't look that dirty they are. That dirt you see is from the bowls
Mark Henry   The Pine-Sol carburetor cleaning thread   Aug 1 2010, 09:02 PM
zymurgist   Cool! I'll be doing this for the Yamaha.....   Aug 1 2010, 09:06 PM
Mark Henry   My first victim of neglect, I haven't cleaned ...   Aug 1 2010, 09:07 PM
zymurgist   Hmmm. My Quadrajet could use a little freshening ...   Aug 1 2010, 09:13 PM
Mark Henry   I'll get right to the before and after shots :...   Aug 1 2010, 09:15 PM
Mark Henry   Let it soak, I tried it overnight but really you o...   Aug 1 2010, 09:18 PM
Mark Henry   Before and after pic's of the 40's   Aug 1 2010, 09:23 PM
Mark Henry   Although the 40's don't look that dirty th...   Aug 1 2010, 09:30 PM
Mark Henry   This is the filth from one carb. :sick:   Aug 1 2010, 09:32 PM
Mark Henry   Here's the bad, first this is not a Weber OE p...   Aug 1 2010, 09:50 PM
Mark Henry   Now I'll have to clean the rest of the engine ...   Aug 1 2010, 10:01 PM
Mark Henry   Once I had them clean I throughly rinsed them in w...   Aug 1 2010, 10:27 PM
Eddie914   Wow! Great find. Look like if you only dip A...   Aug 1 2010, 11:39 PM
Mark Henry   Plus the price is right ... perfect for CSOB tee...   Aug 2 2010, 07:12 AM
Mark Henry   This stuff is amazing, in fact I'm going to fi...   Aug 2 2010, 06:31 AM
Mark Henry   Well I have to say no to the parts washer, this st...   Aug 2 2010, 08:18 AM
Vacca Rabite   So, if PineSol works... I wonder how well Simple G...   Aug 2 2010, 08:47 AM
zymurgist   So, if PineSol works... I wonder how well Simple ...   Aug 3 2010, 05:17 AM
GS Guy   So, if PineSol works... I wonder how well Simple...   Aug 3 2010, 05:33 AM
Root_Werks   That's a pretty cool thread! I've rec...   Aug 2 2010, 08:55 AM
Mark Henry   I've used simple green, Berrymans and Carb-out...   Aug 2 2010, 08:55 AM
Mark Henry   Please review the first post as I'm adding pro...   Aug 2 2010, 09:10 AM
Mark Henry   more pics of fresh pine carbs   Aug 2 2010, 10:26 PM
Mark Henry   The diaphragms on the 40IDA disintegrated, at firs...   Aug 2 2010, 10:33 PM
Mark Henry   Hard to believe these carbs have been in service f...   Aug 2 2010, 10:37 PM
Kirmizi   Well Done! I guess I know what I'll be doi...   Aug 2 2010, 10:42 PM
Mark Henry   Being the cheap ass that I am...I think I figured ...   Aug 2 2010, 10:43 PM
smontanaro   So, you just dunk the entire carb? No disassembly...   Aug 3 2010, 07:39 AM
Mark Henry   So, you just dunk the entire carb? No disassembl...   Aug 3 2010, 08:29 AM
Mark Henry   This is my rinse bucket, just clear water. I alrea...   Aug 3 2010, 08:36 AM
Mark Henry   This shows how I filtered the Pine-Sol. A real goo...   Aug 3 2010, 08:41 AM
Mark Henry   Here is my second 40IDA, the bubbler trick worked,...   Aug 3 2010, 08:49 AM
Mark Henry   The wife just got me a big bottle of Pine-Sol. Lit...   Aug 3 2010, 08:56 AM
DBCooper   You know those motorcycle guys were leaving the ca...   Aug 3 2010, 04:35 PM
smontanaro   OK, who will be the first volunteer to leave their...   Aug 3 2010, 04:40 PM
DBCooper   OK, who will be the first volunteer to leave thei...   Aug 3 2010, 04:43 PM
jmill   That's true, it doesn't seem to lose it...   Aug 3 2010, 06:12 PM
underthetire   I've got to do my dirtbike carb for the winter...   Aug 3 2010, 09:41 PM
76-914   I wonder what the ph is when it's new?   Aug 3 2010, 11:22 PM
Mark Henry   Just an up-date, the 42 DCNF`s are back in my ...   Aug 20 2010, 04:57 AM
jaxdream   I can understand this , years ago although not aut...   Aug 20 2010, 06:01 AM
underthetire   Just bough a gallon of ZEP brand pinesol at the de...   Aug 20 2010, 08:45 AM
kg6dxn   I tried the pinesol. It sucks compared to B12 Carb...   Aug 20 2010, 09:08 AM
zoomCat   I’m resurrecting this thread to check if the new...   Sep 3 2022, 12:17 PM
930cabman   Hats off to Mark starting this informative thread....   Sep 3 2022, 01:13 PM
8 User(s) are reading this topic (8 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 17th April 2025 - 06:11 PM
