malaga_red75 |
'74 2.5L N/A Subie ![]() ![]() Group: Members Posts: 454 Joined: 5-March 06 From: Menlo Park, CA Member No.: 5,674 Region Association: None ![]() |
subaru JDM EJ25 DOHC
So, got my conversion finally road worthy and have noticed that while I am driving around, the car stays at around 200 F. when i stop, or let it idle in my garage... the temp slowly climbs and doesnt stop (i shut it off around 230 F). I am assuming this is an issue with my fans. I am running a front mounted radiator, using 2 push-style fans. A few things that i think may be wrong... -There is no shroud around the fans... just the shroud that seals the radiator to the front (since they are push fans, they are mounted on the front side of the radiator, in between the radiator and the nose of the car) - there is about a 1 1/2" gap between the fans and the radiator (this was just the way that ended up working for mounting the fans) anyways, i am pretty sure that the cooling system is working (no kinked lines, thermostat working, fans do turn on) as indicated by driving and the temp staying cool, there is just something not working when i stop moving. let me know what you guys think. -Peter |
malaga_red75 |
Dave,
I do have a shroud that feeds all the air through the radiator... there is just not a shroud that feeds all the air from the fans, which sounds like it may be the problem. ![]() ![]() My radiator is not from the subaru, but has the same core dimensions as the subaru. I will have to get all the air out as well. what did you use for a vacuum? -Peter |
Lo-Fi Version | Time is now: 20th April 2025 - 12:24 AM |
