swl |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,409 Joined: 7-August 05 From: Kingston,On,Canada Member No.: 4,550 Region Association: Canada ![]() |
DaveP is doing me a new set of front calipers but while I'm waiting I'm trying to free up the front right. It was dragging pretty hard and was the only thing that the car failed on its safety check. If I can get that caliper freed up I can start (IMG:style_emoticons/default/driving.gif)
I followed the haynes instructions for freeing up a stuck caliper. Took out the pads. Put in some wood shims. Applied the brakes until they moved. Felt a little pop as the first side moved. Then a pump or two later the second side moved. So far so good. Now I'm trying to lever the pistons back in but they won't budge. How much force should that take? I feel like I'm putting way more pressure on it than it should need. Starting to wonder if I might have a swollen softline. |
tomeric914 |
One Lap of America in a 914! ![]() ![]() ![]() Group: Members Posts: 1,259 Joined: 25-May 08 From: Syracuse, NY Member No.: 9,101 Region Association: North East States ![]() ![]() |
You didn't mention in your post, what kind of condition you found the pistons and cylinder bores in? The pistons usually clean up pretty easily with some 600 grit paper. The bores you hopefully honed.
If your calipers have knockbacks in them, they will take some force to put back together. |
Lo-Fi Version | Time is now: 25th June 2024 - 09:05 PM |
