> Valve Adjustment, ...why did I have zero clearance?
tomeric914
post Aug 4 2010, 02:18 PM
One Lap of America in a 914!
I had adjusted the valves to .006" before the last track event I went to in April. It was about a 4 hour drive to the track and probably 40 or 50 degrees F. When I got there, the darn thing wouldn't idle (dual IDF 40's, 2.1L). No matter what adjustments I made, I couldn't get it to idle when hot (right off the track) but it would idle if it sat for a while. So I came home from the event, parked the car and started on the flare installation.
Now 3 months later with flares on and driving it on a regular basis, it still didn't idle. Again, checked the synchronization on the carbs, idle mixture, etc. Still didn't idle. Thinking logically, if it won't idle hot, a valve must be sticking open. So I let the car sit for a day and pulled the valve covers to find that all 4 exhaust valves had ZERO (more like negative) clearance! (IMG:style_emoticons/default/WTF.gif)
So what happened?
A. The valves all stretched the same length.
B. All the seats got mashed evenly
C. The valves weren't adjusted at TDC
D. It was about 20 deg F in the garage when I adjusted them last
A and/or B? I doubt it.
D seems the most logical but does the valve grow .006" over 60 degrees?
You would think that finding TDC doesn't matter, but I believe it does. Years ago I tried adjusting them with what is now referred to as the "rocking method" using the opposite side valve as a guide with the theory that a valve closed is a valve closed anywhere on the cam. I found when checking the clearance at TDC that the valve did not have the same clearance as measured when using the rocking method. It ended up being too tight at TDC!
On my 914, the flywheel is paint marked at the groove for TDC and 28 deg BTDC. If I used the 28 deg BTDC mark, I was on another part of the cam that resulted in a different clearance than at TDC. The result being a valve held open when the engine is hot and no idle.
After adjusting the valves at TDC and confirming all adjustment through one rotation, it idles perfectly.
VaccaRabite
post Aug 4 2010, 02:40 PM
En Garde!
Don't use the TDC mark when adjusting valves.
Use the "opposing lobe" method.
Also, make sure that when you tighten down the lock nut, you do not further screw in the valve. That is very common to do, and take practice not to do.
Zach
tomeric914
post Aug 4 2010, 02:48 PM
QUOTE(Vacca Rabite @ Aug 4 2010, 04:40 PM) *
Also referred to as the "rocking method" which doesn't always work. That was my point.
The "rocking" or "opposing lobe" methods assume that the cam base circle has zero runout.
Small base circle cams have the lobes ground down to the core diameter to give extra clearance for connecting rods used on stroker cranks. Higher lift cams also have smaller base circle diameters than stock lift cams.
So if the base circle is ground down, then the clearance won't be the same as at TDC resulting in too tight of a valve.
20+ years of adjusting valves at TDC. This a first I goofed on and adjusted all 8 at the wrong mark (I think).
Don M
post Aug 7 2010, 06:56 AM
QUOTE(tomeric914 @ Aug 4 2010, 01:48 PM) *
You are correct that the opposing lobe method is unreliable but not for the reason you gave. The problem stems from the fact that the vavle must be on the seat (closed) at TDC and depending on cam profile, the lifter is commonly still on the ramp rather than the base circle at this point (TDC) which means that setting the valve at the lowest point on the base circle (opposing lode method) can cause it to be held open (slightly) at TDC.
jeffdon
post Aug 9 2010, 02:08 PM
QUOTE(Don M @ Aug 7 2010, 05:56 AM) *
Awe hell, i used the lobe method......494 cam, with 0.465 lift, 280 duration, 108 degree lobe center. Think i am ok?
VaccaRabite
post Aug 10 2010, 09:34 AM
En Garde!
QUOTE(jeffdon @ Aug 9 2010, 03:08 PM) *
I used to have that exact cam in my car, and did valves both ways to see if the opposing lobe method really worked. It worked perfect.
I am now using a cam very similar to the 494 (same lift, but longer duration on exhaust) and guess what. It still works.
All the folks that claim it does not work have probably never tried it to see for themselves. Whatever, its their car. I have tried both ways, and you will be fine using the opposing lobe method to set your valves.
Zach
tomeric914
post Aug 10 2010, 01:49 PM
QUOTE(Vacca Rabite @ Aug 10 2010, 11:34 AM) *
(IMG:style_emoticons/default/wacko.gif) I've tried both ways. The opposing lobe method is inconsistent.
It worked for the 2 cams in particular that you have adjusted valves on which is great. You know it works for those, so stick with it.
tomeric914   Valve Adjustment   Aug 4 2010, 02:18 PM
Vacca Rabite   Don't use the TDC mark when adjusting valves. ...   Aug 4 2010, 02:40 PM
tomeric914   Don't use the TDC mark when adjusting valves....   Aug 4 2010, 02:48 PM
Don M   Don't use the TDC mark when adjusting valves...   Aug 7 2010, 06:56 AM
jeffdon   [quote name='tomeric914' post='1352154' date='Aug...   Aug 9 2010, 02:08 PM
ME733   [quote name='tomeric914' post='1352154' date='Au...   Aug 9 2010, 05:12 PM
tomeric914   Awe hell, i used the lobe method......494 cam, wi...   Aug 9 2010, 05:50 PM
ME733   Awe hell, i used the lobe method......494 cam, w...   Aug 10 2010, 08:53 AM
Vacca Rabite   Awe hell, i used the lobe method......494 cam, wi...   Aug 10 2010, 09:34 AM
ME733   Awe hell, i used the lobe method......494 cam, w...   Aug 10 2010, 09:54 AM
Vacca Rabite   ..................If you are satisfied with getti...   Aug 10 2010, 10:45 AM
tomeric914   All the folks that claim it does not work have pr...   Aug 10 2010, 01:49 PM
vsg914   Just curious, why is your flywheel marked at 28btd...   Aug 4 2010, 04:09 PM
Root_Werks   Valve seats letting the valves settle in a little ...   Aug 4 2010, 05:20 PM
tomeric914   Just curious, why is your flywheel marked at 28bt...   Aug 4 2010, 06:24 PM
realred914   Just curious, why is your flywheel marked at 28b...   Aug 4 2010, 10:56 PM
ME733   I had adjusted the valves to .006" before th...   Aug 7 2010, 05:17 PM
tomeric914   .........................Well you have experience...   Aug 7 2010, 05:40 PM
ME733   .........................Well you have experienc...   Aug 8 2010, 06:17 AM
ME733   [quote name='tomeric914' post='1353499' date='Aug...   Aug 9 2010, 09:55 AM
jaxdream   Ok , TDC it is , but is it TDC for every cylinder ...   Aug 8 2010, 07:20 AM
tomeric914   .................And...when building any engine ...   Aug 8 2010, 10:01 AM
vsg914   Find the notch in the flywheel with your finger th...   Aug 8 2010, 10:34 AM
jaxdream   Thanks , Tom , that clears up a lot. :Qarl: Jack...   Aug 8 2010, 06:30 PM
bandjoey   :blink: :blink: :blink: :blink: :blink: :blin...   Aug 10 2010, 10:23 AM
9 User(s) are reading this topic (9 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 8th April 2025 - 06:34 AM
