> Need Radio Installation Help, Please!, Have an original to install...
orthobiz
post Aug 10 2010, 03:08 PM
My 1974 came with a junkie Kenwood CD player that skips over every bump. I have a radio that came out of a 1975 914 but need advice please on installation. The Kenwood has a proprietary plug connected to a bunch of wires, maybe 7 or 8. I suspect the original Porsche wiring is cut to fit into the special plug that goes into the back of this monstrosity.
In looking at the original Blaupunkt radio, I only see 4 wires and a hole for the antenna connector. Wouldn't each speaker need two wires (total 4), a 12V hot wire and a ground for a minimum of 6? What's with the special plug coming out of the radio: is it only one of two speaker connectors (like the other one is missing?).
Any help is appreciated.
Paul
Mike Bellis
post Aug 10 2010, 03:39 PM
Resident Electrician
That radio was made before the switch to floating speaker grounds. The speaker negative could be the vehicle chassis unless it is a mono unit. It it is mono, there is only a single speaker channel and your funky connector could be both positive and negative speaker leads.
orthobiz
post Aug 10 2010, 03:59 PM
QUOTE(kg6dxn @ Aug 10 2010, 05:39 PM) *
Then it's gotta be mono. I'm SURE it would say "Stereo" on it otherwise, no? Shouldn't be any harm in splitting the signal from that dual connector then, one positive and one negative wire sent to each speaker then.
Paul
Mike Bellis
post Aug 10 2010, 04:23 PM
QUOTE(orthobiz @ Aug 10 2010, 02:59 PM) *
Paul
If it is mono, you will damage it if you wire the speakers in paralelle. You need to wire them in series. For a series circuit, Left speaker positive to radio. Left speaker negative to Right speaker positive. Right speaker negative to radio. This will double the speaker impeedance and protect the amplifier circuit. If they are wired in paralelle, it will half the load and burn out the radio.
orthobiz   Need Radio Installation Help, Please!   Aug 10 2010, 03:08 PM
orthobiz   The Kenwood.   Aug 10 2010, 03:09 PM
orthobiz   The Blaupunkt.   Aug 10 2010, 03:13 PM
jim_hoyland   What are the wire colors ? They are somewhat unive...   Aug 10 2010, 03:14 PM
orthobiz   What are the wire colors ? They are somewhat univ...   Aug 10 2010, 03:18 PM
orthobiz   More...   Aug 10 2010, 03:15 PM
orthobiz   Finally, Two faceplates. Think I like the "i...   Aug 10 2010, 03:17 PM
vsg914   One wire goes to power, two to each speaker +, and...   Aug 10 2010, 03:18 PM
orthobiz   Concerning the speakers, it just looks like 2 brow...   Aug 10 2010, 03:25 PM
Tom_T   Just looked at my Motorola made VW4412 AM/FM/8-Tra...   Aug 10 2010, 03:28 PM
kg6dxn   That radio was made before the switch to floating ...   Aug 10 2010, 03:39 PM
orthobiz   That radio was made before the switch to floating...   Aug 10 2010, 03:59 PM
kg6dxn   That radio was made before the switch to floatin...   Aug 10 2010, 04:23 PM
orthobiz   Could this be the connector? This would indicate t...   Aug 10 2010, 04:11 PM
kg6dxn   Could this be the connector? This would indicate ...   Aug 10 2010, 04:26 PM
orthobiz   I would not waste money on that connector. A stan...   Aug 10 2010, 07:09 PM
RJMII   I have brown wires under my dash like that; they g...   Aug 11 2010, 01:13 AM
windforfun   Mono. Best to wire speakers in series. What...   Aug 11 2010, 10:38 AM
orthobiz   Mono. Best to wire speakers in series. What...   Aug 11 2010, 07:07 PM
realred914   yup, mono, I had that once. the time before stere...   Aug 11 2010, 12:22 PM
RJMII   Here, you go; two wires in, and 4 out. (one pair i...   Aug 11 2010, 09:05 PM
windforfun   Balance control (left to right)?   Aug 12 2010, 05:01 PM
- Lo-Fi Version Time is now: 6th January 2025 - 07:28 PM
