Motor Won't Turn Over Fast Enough |
adambo |
Aug 11 2010, 12:14 PM
Newbie Group: Members Posts: 25 Joined: 8-September 09 From: Boulder, Colorado Member No.: 10,776 Region Association: Rocky Mountains |
Hey I just did a full rebuild and now when trying to start it up, with a fresh battery, it turns over but super slow. Jumping doesn't help. Could it be a problem with the motor itself? Or starter?
-Adam |
realred914 |
Aug 11 2010, 12:18 PM
Senior Member Group: Retired Members Posts: 1,086 Joined: 1-April 10 From: california Member No.: 11,541 Region Association: None |
Hey I just did a full rebuild and now when trying to start it up, with a fresh battery, it turns over but super slow. Jumping doesn't help. Could it be a problem with the motor itself? Or starter? -Adam well you could confirm what voltage y9u have at the starter when you crank. confirm you have the ground strap re-attached on the tranny to body for sure. check any other connections you might have moved also. the motor might be super tight, try cranking with the sparkplugs removed, does it get better? if not, then suspect the probelm is more likely the starter/starter power than a tight motor. goodluck |
Lo-Fi Version | Time is now: 23rd June 2024 - 01:57 PM |
