Weber IDF Main jet help |
tornik550 |
Aug 11 2010, 07:29 PM
Senior Member Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
I am in the process of tuning my car after a rebuild. I have dual weber 40's. My engine is a 2.27L. Everything is going pretty well. I am slowly getting the jetting closer and closer. I was driving around at about 60mph yesterday. The head were hotter than I like (325 degrees). I checked the spark plugs and they were bone white. The main jets were at 160. I increased them to 170 (above 160 I only have increments of 10). With the increase to 170, the car is running very well and the temp at around 60mph cruising is around 275. I sped home, tuned off the car and took out the plugs- bone white. I was quite surprised.
The main jet size sounds high too me. Does it sound high to everyone else? Is it possible that I am needing a high main jet size because of the float level? I have my floats set at 10.5 with the gasket. Any opinions would be greatly appreciated |
jmill |
Aug 12 2010, 11:10 AM
Green Hornet Group: Members Posts: 2,449 Joined: 9-May 08 From: Racine, Wisconsin Member No.: 9,038 Region Association: Upper MidWest |
The AIR correction jet has a very significant change to the air fuel ratio, much more so than a single main jet step change...something like a 2 -3 main jet size change...and the smaller air correction jet will enhance the upper rpm range, by making it richer, far more than a main jet change/ or even two.(sizes larger I haven't found the changes quite as significant. The 220 AC jet will definately lean your mixture up at higher velocities. As I stated earlier you'll see those velocities at lower RPM due to your vent/engine size. |
Lo-Fi Version | Time is now: 25th September 2024 - 11:02 PM |
