familienauto |
Volksporsche ![]() ![]() Group: Members Posts: 136 Joined: 5-November 06 From: UW Seattle Member No.: 7,156 Region Association: Pacific Northwest ![]() |
73 1.7 D-jet, vacuum advance stock distributor.
First time I have set the timing on this car myself, but used to doing it on VWs with Type I and IV engines. The fan has two marks, a "0" for TDC, and a red notch for 27 BTDC. Distributor vacuum hoses removed and plugged. Even with the distributor turned as far clockwise as it will go, the timing is (according to the marks on the fan) at least 10-15 degrees too advanced at 3500 RPM. Is the logical explanation that the fan was somehow installed incorrectly? The car was running fine, I pulled the distributor to clean the trigger points. I marked how it was lined up before, so I'm tempted to just put it back, but this is a little unnerving. |
tod914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,755 Joined: 19-January 03 From: Lincoln Park, NJ Member No.: 170 ![]() |
The timing light goes onto plug wire 1. As your standing behind the car and facing foward, it would be the one in the 10 o'clock possition on the cap. Might want to double check that.
Lo-Fi Version | Time is now: 24th June 2024 - 07:40 AM |
