jabberwocky |
Newbie ![]() Group: Members Posts: 40 Joined: 24-April 10 From: Cleveland OH Member No.: 11,653 Region Association: None ![]() |
Ok about a month ago my transmission got stuck in 4th gear. I got it unstuck by removing the side shift comb and reseting it with a screwdriver. I have done this two times now. I then got a copy of Dr Evil's transmission rebuild video and watched it took my tranmission down and "realigned" my shifter forks following the instructions on the video. I put the transmission back together installed and today It got stuck in 4th again (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) . I obviously did not fix the problem. Is there a trick I am missing on the alignment. is this a different issue other than alignment worn comb ect. or should I be looking for a new transmission . Other than getting stuck in 4th the transmission shifted very well and no grinding in any gears. I do have a tail shift transmission sitting in my garage but dont know if this would be any help. Any help is appreciated.
Richard Casto |
Blue Sky Motorsports, LLC ![]() ![]() ![]() Group: Members Posts: 1,465 Joined: 2-August 05 From: Durham, NC Member No.: 4,523 Region Association: South East States ![]() |
When you say it is stuck in 4th gear, I am assuming you are meaning you can't use the lever on the shift console to put it back into neutral. When the shift console is in place, and it's in 4th gear, what happens when you do try to shift it into neutral via the lever on the console? What position is the lever in and how much and in what direction can you move it?
Normally you would expect that when in 4th gear that you can only move it a small bit in the 4th/5th plain (rotate lever) and you would have no (or very little) movement of the lever in/out. Is that the case? I am trying to get a feel for where the disconnect is between the shift console and the rods. Have you read the supplementary material (pdf file) for the video that you can find here on the forum (in Dr Evil's signature area on his posts). It has good info on shifting issues. |
Lo-Fi Version | Time is now: 22nd June 2024 - 08:52 PM |
