Marlow |
Member ![]() ![]() Group: Members Posts: 311 Joined: 14-August 03 From: Manassas, VA Member No.: 1,027 ![]() |
Getting ready to place an order for parts for my transmission rebuild and was looking for opinions on which of my synchro rings are good enough to flip.
In the picture the order they came out of the transmission is 1st, 2nd/3rd, 4th/5th. It's obvious that 1st is done. 3rd looks to me like I could reuse it, very little wear. What about 2 and 4/5? The coating on 2 is a little rounded at the peak. On 4/5 the moly coating is worn just past the half point of the peak. Would these be considered good enough to flip or should I replace them? Attached image(s) ![]() ![]() |
PRS914-6 |
Excellence Magazine Project 914 3.6 ![]() ![]() ![]() Group: Retired Members Posts: 1,278 Joined: 20-May 06 From: Central California Member No.: 6,031 Region Association: None ![]() ![]() |
There is more to the story than the syncro side that faces the slider. Replace them all while it's apart. Dog tooth is probably shot on first and most likely the slider.
When you flip the syncro, the worn area is now in the dog tooth side and that effects the overall OD of the syncro. Do it once....do it right |
Lo-Fi Version | Time is now: 24th June 2024 - 07:20 AM |
