jeffdon |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,094 Joined: 24-October 06 From: oakland, ca Member No.: 7,087 Region Association: None ![]() |
Damn, I am having a devil of a time getting the passenger side to fit. ANyone have a trick for making this work? Drivers side went in easy. This side, cannot get the holes for the screws anywhere near lining up. Heat in boiling water maybe?
gasman |
Member ![]() ![]() Group: Members Posts: 107 Joined: 21-January 08 From: Mooresville, nc Member No.: 8,602 Region Association: South East States ![]() |
Going from an aging memory, I remember there are three 10mm bolts behind the door panel that goes to the front window guide and triangle window. When you loosen these bolts, go to the bottom adjustment nut with a screw in the middle. (it's located all the way on the bottom front of door)The screw will bring the triangle window and window channel out and in, the nut while loose, will let you move the window channel front and back. If you pull it toward the rear of car, that space you have will close. Tighten the nut. tighten up the three nuts you loosened to allow the window channel to move....I hope you understand because it's a little hard to explain.
Lo-Fi Version | Time is now: 25th June 2024 - 12:49 AM |
