Spoke |
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,997 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None ![]() ![]() |
I put in SS fuel lines tonight and I've got a few questions.
The engine side of the SS lines looks fine. No issues here. ![]() On the tank side, both fuel lines seem to come out too forward towards the front of the car. The one on the left of the pic is pointing directly into the bulkhead and is touching the bulkhead. Question: Should I try to bend the fuel lines to make some clearance for hoses? I don't want to kink the lines. ![]() The shorter SS fuel lines go through the tin and I don't have the original rubber gaskets. Question: Can these be purchased new or taken off of parts cars or other type of homemade grommet? ![]() I'm assuming the bendable tabs that are shown holding the fuel lines are for the fuel lines, correct? I don't have a FI car to look at. ![]() |
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
I made my own. Ran the tubes through and bent the fronts, then bent the rears after pulling them back slightly.
If you can push the tubes through the front firewall a tad more you can probably get the bender on them. You could try sticking a large phillips screwdriver in the tube and levering up on it slightly till you get clearance. Just don't try for a great amount. |
Lo-Fi Version | Time is now: 30th June 2024 - 01:09 PM |
