7TPorsh |
7T Porsh ![]() ![]() ![]() ![]() Group: Members Posts: 2,691 Joined: 27-March 06 From: Glendale Ca Member No.: 5,782 Region Association: Southern California ![]() ![]() |
I'm going through dash lights and trying to figure out why some stuff doesn't work. Tried search but am not finding direct resolutions.
I have a 1970 with a 2.0 block, dual webers. I am assuming that the "upgrade" is common one and was done at the same time. hopefully a cam in there somewhere. At some time the center console was added. With all this 'work", the engine compartment now has tapped and chopped wires, and other loose wires of different color (these don't get power with ignition), etc. (IMG:style_emoticons/default/mad.gif) Most all electric works except for the following: So I am thinking i have just have to rewire certain things directly. 1- (not working) Tach is getting power and all connections seem stock...of the few loose wires, engine compartment has no visible "brown" wire and nothing is connected to the neg side of the coil other than one wire going to the distributor. 2- I have a temp gauge (gets power doesn't work) in the center console that isn't labeled and goes to 300 so i guess it's oil temp. it gives off one green/blk striped wire that is cut and attached to a purple wire (DAPO?) that disappears down next to the shifter...in the engine compartment there is a purple wire (hopefully the same wire?) attached to the sensor just back and left of the distributor. I changed this sensor (when the old one leaked) with one that was included with the car. Sensor only has one terminal. I don't think it worked before that either) Idiot pressure light lightens when I start the car but goes out. I question...is this sensor for the idiot light? (IMG:style_emoticons/default/chair.gif) Is this the right gauge for the console? I don't think I have the Taco plate sensor (assuming it's easy to see in the center of the oil sump. Are the oil pressure and oil temp senders similar sizing? All mixed up. (IMG:style_emoticons/default/headbang.gif) 3- With the car off, clicking the turn signal lever sets off the headlight motors (not the lights) going up and down repeatedly. Kinda funny actually. they start out even and then go out of sync...like it's getting dizzy. I know this is wrong. Should anything happen? I thought I read somewhere that the left and right side of the car is supposed to light...like modern cars. (IMG:style_emoticons/default/dry.gif) >_> What in the bindle of wires that come up through the various hole in the engine tin? Appreciate all suggestions, remarks, etc... |
VaccaRabite |
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,475 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region ![]() |
I agree with Spoke.
If you pull the harness, you are going to be down for weeks. If you take it one wire at a time, you can be done in a weekend. Get a wire diagram for your car. There is one in the Hayens manual, and you can find color diagrams here and from AA. When I was tackling wires, I actually made the color wire diagram the background of my computer screen at home and at work. I looked at it for hours a day while doing other things, and got familiar with how things were supposed to work. It has made my electrical life easier. Go one wire at a time and you can tear through it. if you look at it as a whole you are going to get overwhelmed. Zach |
Lo-Fi Version | Time is now: 25th June 2024 - 12:43 AM |
