Spoke |
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,998 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None ![]() ![]() |
I put in SS fuel lines tonight and I've got a few questions.
The engine side of the SS lines looks fine. No issues here. ![]() On the tank side, both fuel lines seem to come out too forward towards the front of the car. The one on the left of the pic is pointing directly into the bulkhead and is touching the bulkhead. Question: Should I try to bend the fuel lines to make some clearance for hoses? I don't want to kink the lines. ![]() The shorter SS fuel lines go through the tin and I don't have the original rubber gaskets. Question: Can these be purchased new or taken off of parts cars or other type of homemade grommet? ![]() I'm assuming the bendable tabs that are shown holding the fuel lines are for the fuel lines, correct? I don't have a FI car to look at. ![]() |
jcb29 |
Member ![]() ![]() Group: Members Posts: 89 Joined: 29-August 04 From: Clovis, CA Member No.: 2,646 Region Association: Central California ![]() |
The bends in the SS tubes just aft of the fire wall look the same as on the Tangerine lines I just installed and they will not interfere with anything in the engine bay. You might want to verify the correct location of the two short lines. Either you or I have them installed incorrectly. I mounted my short ones with the 90 bend under the shelf so the straight portions protrudes up through the shelf about 2-3 inches.
Maybe someone from Tangerine could clarify the question of mounting for the short tubes. |
ejm |
I can see the light at the end of the tunnel ![]() ![]() ![]() ![]() Group: Members Posts: 2,696 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None ![]() |
You might want to verify the correct location of the two short lines. Either you or I have them installed incorrectly. I mounted my short ones with the 90 bend under the shelf so the straight portions protrudes up through the shelf about 2-3 inches. The pictures show the correct installation of the short lines. |
Lo-Fi Version | Time is now: 2nd July 2024 - 09:15 AM |
