r3dplanet |
Senior Member ![]() ![]() ![]() Group: Members Posts: 679 Joined: 3-September 05 From: Portland, Oregon Member No.: 4,741 Region Association: None ![]() |
Because I can't leave things alone, and maybe because I'm always trying to figure out the last 3% of why my 1971 1.7l engine doesn't purr exactly right, I spent some time with the Haynes manual to look things over.
I thought I had checked out the fuel pressure valve before, but I never really have. The book says (as do several knowledgeable D-Jet wizards) to set the pressure at 30psi. Mine is set to 35psi. Five pounds too much. Huh. So I adjusted it back to 30psi and the car ran terrible. I thought there might be a change in timing and I was right, but even by re-timing the engine it still ran horrible. So I pushed it back to 35psi. Now it works. Mostly. But this raises a question. Why is it set so high? I nudged it up a little higher to 36 or so and it actually ran a tiny bit better. I don't like setting it so high, so I'm confused. The fuel pump isn't stock as far as I can tell. Or least it doesn't look at all like the one in the Haynes manual. Any thoughts? |
benalishhero |
Member ![]() ![]() Group: Members Posts: 313 Joined: 28-November 07 From: Portland, Maine Member No.: 8,384 Region Association: North East States ![]() |
My 2.0 had the same problem for two summers. The car ran great at a high PSI but when I brought it down to spec it would run like crap. It ended up being partially clogged injectors. Well actually just the two new injectors I had in the car were having "spray issues".
It turns out the E-10 gas we have in the northeast was the culprit. Now I use a fuel stabilizer with ethanol treatment and the problem has not returned this summer. |
Lo-Fi Version | Time is now: 28th June 2024 - 12:35 AM |
