After market headlights, final fitting to occur when the car gets painted |
Mike Bellis |
Apr 25 2010, 11:50 AM
Resident Electrician Group: Members Posts: 8,346 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
I saw a member from Purto Rico use these. I thought I would give it a try. They are for a Nissan 240SX. After 40 hours of cutting and fiberglass, (IMG:style_emoticons/default/sawzall-smiley.gif) they fit pretty well. I will fix the gaps and do some clean up after I strip the body for paint. Fender lines are not straight due to bondo. The slant angle is extreemly close to the 914. (IMG:style_emoticons/default/smilie_pokal.gif) Each lamp can be adjusted up/down and side to side.
Specs: H7 lamps, LED halo (white/blue color) comes with wire harness with relay for high beam (high beams illuminate all 4 lamps) If you want to do this too, I recommend a cardboard template of the stock lamp covers. There are no right angles on the 914 headlamps. the template will be smaller than the overall size of the 240sx assembly. find a good fit and cut larger than your marks. Trip and shape slowly. once you have your shape, reinforce the bottom with fiberglass (Kitty Hair and gel). I then mounted some L brackets to the factory mounting holes. I set some wet glass to the brackets and "glued" the assembly in place. Rivet nuts on the brackets make removing easy. Use large washers and open up the factory holes to make final adjustment easy. |
matthepcat |
Jul 28 2010, 03:32 PM
Meat Popsicle Group: Members Posts: 1,462 Joined: 13-December 09 From: Saratoga CA Member No.: 11,125 Region Association: Northern California |
I pulled the trigger and am becoming a copy cat.
Accept I am going to try to retrofit a Bi-Xenon projector into one of the halogen housings. That part may be tough (IMG:style_emoticons/default/rolleyes.gif) (IMG:http://www.914world.com/bbs2/uploads_offsite/img693.imageshack.us-11125-1280352749.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/img525.imageshack.us-11125-1280352749.2.jpg) Wish me luck. |
TurboWalt |
Aug 20 2010, 07:52 PM
Member Group: Members Posts: 157 Joined: 14-March 10 From: Chattanooga, TN Member No.: 11,463 Region Association: Northern California |
I pulled the trigger and am becoming a copy cat. Accept I am going to try to retrofit a Bi-Xenon projector into one of the halogen housings. That part may be tough (IMG:style_emoticons/default/rolleyes.gif) (IMG:http://www.914world.com/bbs2/uploads_offsite/img693.imageshack.us-11125-1280352749.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/img525.imageshack.us-11125-1280352749.2.jpg) Wish me luck. Matt, Any luck with fitting the Bi-Xenon's? Walt |
matthepcat |
Aug 21 2010, 11:24 AM
Hey Walt,
Yea I got them in there as in the photos above. I had to make some custom adjustment screws. Once I get the shroud fabricated it will look nice. The lights are wired up and functional. (high & low beam bi-xenon) I am using one of the smallest bi-xenon projectors called : Morimoto Mini The best place to get them is www.theretrofitsource.com (IMG:style_emoticons/default/smile.gif) I pulled the trigger and am becoming a copy cat. Accept I am going to try to retrofit a Bi-Xenon projector into one of the halogen housings. That part may be tough (IMG:style_emoticons/default/rolleyes.gif) (IMG:http://www.914world.com/bbs2/uploads_offsite/img693.imageshack.us-11125-1280352749.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/img525.imageshack.us-11125-1280352749.2.jpg) Wish me luck. Matt, Any luck with fitting the Bi-Xenon's? Walt |
Lo-Fi Version | Time is now: 26th November 2024 - 06:35 AM |
