> After market headlights, final fitting to occur when the car gets painted
Mike Bellis
post Apr 25 2010, 11:50 AM
Resident Electrician
I saw a member from Purto Rico use these. I thought I would give it a try. They are for a Nissan 240SX. After 40 hours of cutting and fiberglass, (IMG:style_emoticons/default/sawzall-smiley.gif) they fit pretty well. I will fix the gaps and do some clean up after I strip the body for paint. Fender lines are not straight due to bondo. The slant angle is extreemly close to the 914. (IMG:style_emoticons/default/smilie_pokal.gif) Each lamp can be adjusted up/down and side to side.
Specs: H7 lamps, LED halo (white/blue color) comes with wire harness with relay for high beam (high beams illuminate all 4 lamps)
If you want to do this too, I recommend a cardboard template of the stock lamp covers. There are no right angles on the 914 headlamps. the template will be smaller than the overall size of the 240sx assembly. find a good fit and cut larger than your marks. Trip and shape slowly. once you have your shape, reinforce the bottom with fiberglass (Kitty Hair and gel). I then mounted some L brackets to the factory mounting holes. I set some wet glass to the brackets and "glued" the assembly in place. Rivet nuts on the brackets make removing easy. Use large washers and open up the factory holes to make final adjustment easy.
charliew
post Aug 22 2010, 10:46 PM
Great info thanks, you saved me lots of time studying up on this. To me lights are boring until I need them, then they are never bright enough.
kg6dxn   After market headlights   Apr 25 2010, 11:50 AM
vsg914   Someones gotta ask. Why? :confused:   Apr 25 2010, 12:02 PM
kg6dxn   Someones gotta ask. Why? :confused: Just becaus...   Apr 25 2010, 12:03 PM
RJMII   I kind of like it. This was (could still be) on my...   Apr 25 2010, 12:12 PM
kg6dxn   I kind of like it. This was (could still be) on m...   Apr 25 2010, 12:57 PM
JRust   I'd kind of like to have those where the fogli...   Apr 25 2010, 12:20 PM
kg6dxn   I'd kind of like to have those where the fogl...   Apr 25 2010, 12:59 PM
Loser_Cruiser   I like it :trophy: I was wondering if maybe some...   Apr 25 2010, 12:28 PM
kg6dxn   I like it :trophy: I was wondering if maybe som...   Apr 25 2010, 01:08 PM
effutuo101   Well done! now the question is, can you make a...   Apr 25 2010, 12:29 PM
kg6dxn   Well done! now the question is, can you make ...   Apr 25 2010, 01:05 PM
rsrguy3   I was wondering...... How about stuffing them into...   Apr 25 2010, 12:40 PM
70_914   I have been wanting to do this myself... thanks f...   Apr 25 2010, 01:01 PM
Sleepin   Pretty cool and unique! I would put them on my...   Apr 25 2010, 01:08 PM
kg6dxn   Pretty cool and unique! I would put them on m...   Apr 25 2010, 01:18 PM
Cap'n Krusty   Pretty cool and unique! I would put them on ...   Jul 28 2010, 05:43 PM
computers4kids   Another way you could approach a mod like this wou...   Apr 25 2010, 01:33 PM
Sleepin   The quad lights definetly make it look more 914/8i...   Apr 25 2010, 02:00 PM
matthepcat   I pulled the trigger and am becoming a copy cat. ...   Jul 28 2010, 03:32 PM
TurboWalt   I pulled the trigger and am becoming a copy cat. ...   Aug 20 2010, 07:52 PM
matthepcat   Hey Walt, Yea I got them in there as in the photo...   Aug 21 2010, 11:24 AM
kg6dxn   I am doing another set too. TurboWalt has commisio...   Jul 28 2010, 04:03 PM
budman5201   I am doing another set too. TurboWalt has commisi...   Jul 28 2010, 04:11 PM
kg6dxn   [quote name='kg6dxn' post='1349203' date='Jul 28 ...   Jul 28 2010, 04:19 PM
matthepcat   I am doing another set too. TurboWalt has commisi...   Jul 28 2010, 05:42 PM
kg6dxn   [quote name='kg6dxn' post='1349203' date='Jul 28 ...   Jul 28 2010, 06:56 PM
Ferg   I want to see somebody integrate these into a 914 ...   Jul 28 2010, 04:22 PM
kg6dxn   I want to see somebody integrate these into a 914...   Jul 28 2010, 04:29 PM
rickthejetman   what h7/halo kit did you use? i dont seam to be ab...   Jul 28 2010, 07:22 PM
kg6dxn   what h7/halo kit did you use? i dont seam to be a...   Jul 28 2010, 08:26 PM
rickthejetman   what h7/halo kit did you use? i dont seam to be ...   Jul 28 2010, 10:15 PM
matthepcat   Ok....so this job is not easy. Took about 4 hours ...   Jul 29 2010, 01:01 PM
kg6dxn   Very nice. The only thing I did different is the t...   Jul 29 2010, 02:02 PM
matthepcat   Yea that would have been a better method. I mostly...   Jul 29 2010, 02:17 PM
kg6dxn   Yea that would have been a better method. I mostl...   Jul 29 2010, 02:32 PM
matthepcat   Here is a little update. Currently I have the HI...   Aug 20 2010, 07:13 PM
charliew   Is this kit the one you guys started with? It come...   Aug 22 2010, 10:03 PM
kg6dxn   Is this kit the one you guys started with? It com...   Aug 22 2010, 10:25 PM
charliew   I get the jist of it to be two extra hid bulbs and...   Aug 22 2010, 10:29 PM
kg6dxn   I get the jist of it to be two extra hid bulbs an...   Aug 22 2010, 10:42 PM
charliew   Great info thanks, you saved me lots of time study...   Aug 22 2010, 10:46 PM
kg6dxn   :bump: I'm getting ready to start work on Turb...   Jan 20 2011, 09:47 PM
Series9   Thank you.   Jan 20 2011, 10:14 PM
charliew   I finally decided to get some of these I hope the ...   Jan 21 2011, 09:28 AM
kg6dxn   I finally decided to get some of these I hope the...   Jan 21 2011, 09:40 AM
charliew   It will be interesting to see if I can cut them an...   Jan 21 2011, 09:51 AM
kg6dxn   It will be interesting to see if I can cut them a...   Jan 21 2011, 09:57 AM
charliew   Thanks for all your input Mike it has really been ...   Jan 21 2011, 03:56 PM
kg6dxn   Thanks for all you input Mike it has really been ...   Jan 21 2011, 05:07 PM
chuckc   The gel is an Evercoat product. I get it at Krage...   Jan 26 2012, 04:19 PM
charliew   I like the idea of holding it's shape before y...   Jan 21 2011, 07:00 PM
914Timo   Saw them first time and I have to say that they lo...   Jan 22 2011, 04:19 PM
kg6dxn   Saw them first time and I have to say that they l...   Jan 22 2011, 04:21 PM
24 User(s) are reading this topic (24 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 26th November 2024 - 06:38 AM
