Changed the clutch, one more question... |
ripper911 |
Aug 22 2010, 05:41 PM
corde pulsum tangite Group: Members Posts: 2,920 Joined: 25-April 10 From: Powder Springs, GA Member No.: 11,654 Region Association: South East States |
Well, we got everything changed and back together.
I crank the car up and it just grinds when trying to shift. (IMG:style_emoticons/default/headbang.gif) Heres what I know... we didn't remove the flywheel/crankshaft seal so the shims were not messed with I used the rebuilt flywheel (although it looked awefully clean) so I thought we might have to do the shims but didn't think we would be able to do it with what we had available.. I've adjusted the cable at the release fork as much as it can, the pedal feels very tight, and the end of the fork hits the transmision case. I've read about shimming the ball in the bell housing of the tranny, but how? is that what we should do next, or go in and get the shims behind the flywheel in spec? we shifted the transmission while trying to get it back on the engine, whould that have thrown something off? not sure what to do next? |
Cap'n Krusty |
Aug 23 2010, 06:59 PM
Did you replace the plastic ball cup on the release arm? While I'm saking questions, here's a BIG one. Did you replace the o-ring in the back of the flywheel? How about the pilot bearing? For the ball, you need a deep 9/16 socket with the splines going all the way down the inside of the socket. Hard to find, but they DO exist. Use one of the washers from the nose cover of the trans. Be sure to pus another washer in its place. The original washers are of a higher quality than the ones you find in the aftermarket, and they're FLAT.
The Cap'n |
ripper911 |
Aug 24 2010, 04:55 AM
Did you replace the plastic ball cup on the release arm? While I'm saking questions, here's a BIG one. Did you replace the o-ring in the back of the flywheel? How about the pilot bearing? For the ball, you need a deep 9/16 socket with the splines going all the way down the inside of the socket. Hard to find, but they DO exist. Use one of the washers from the nose cover of the trans. Be sure to pus another washer in its place. The original washers are of a higher quality than the ones you find in the aftermarket, and they're FLAT. The Cap'n The O-ring at the back of the flywheel, crankshaft seal? then no. Didn't think we would be able to set the end play right so left it alone. Might have to do it... I'm going to try to get the pivot ball off, I can visualize what I might be able to do to a socket to make it work, grinding it down and such. Thanks for all the help guys! Back to work (job) I'll try again thursday. |
Cap'n Krusty |
Aug 24 2010, 07:39 AM
Did you replace the plastic ball cup on the release arm? While I'm saking questions, here's a BIG one. Did you replace the o-ring in the back of the flywheel? How about the pilot bearing? For the ball, you need a deep 9/16 socket with the splines going all the way down the inside of the socket. Hard to find, but they DO exist. Use one of the washers from the nose cover of the trans. Be sure to pus another washer in its place. The original washers are of a higher quality than the ones you find in the aftermarket, and they're FLAT. The Cap'n The O-ring at the back of the flywheel, crankshaft seal? then no. Didn't think we would be able to set the end play right so left it alone. Might have to do it... I'm going to try to get the pivot ball off, I can visualize what I might be able to do to a socket to make it work, grinding it down and such. Thanks for all the help guys! Back to work (job) I'll try again thursday. Typically flywheels don't come with that o-ring installed, and you're gonna have a massive oil leak, right on to your new disc. The Cap'n |
Lo-Fi Version | Time is now: 20th June 2024 - 11:34 PM |
