ripper911 |
corde pulsum tangite ![]() ![]() ![]() ![]() Group: Members Posts: 2,920 Joined: 25-April 10 From: Powder Springs, GA Member No.: 11,654 Region Association: South East States ![]() |
Well, we got everything changed and back together.
I crank the car up and it just grinds when trying to shift. (IMG:style_emoticons/default/headbang.gif) Heres what I know... we didn't remove the flywheel/crankshaft seal so the shims were not messed with I used the rebuilt flywheel (although it looked awefully clean) so I thought we might have to do the shims but didn't think we would be able to do it with what we had available.. I've adjusted the cable at the release fork as much as it can, the pedal feels very tight, and the end of the fork hits the transmision case. I've read about shimming the ball in the bell housing of the tranny, but how? is that what we should do next, or go in and get the shims behind the flywheel in spec? we shifted the transmission while trying to get it back on the engine, whould that have thrown something off? not sure what to do next? |
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
Somewhere in this thread I thought I told you they were all fitted with 3 shims. One thick and two thinner ones.
You put two shims on to start (thick & thin), measure the endplay and then calculate the thickness required for the 3rd shim. They are probably available from VW or VW parts houses. If not, you have to rely on the board members to find the one you are looking for (or have a couple of spare engines around). Hopefully, the ones you have will get you into the correct endplay range and you won't have to search for one. |
Lo-Fi Version | Time is now: 20th June 2024 - 11:37 PM |
