precisionchassis |
Member ![]() ![]() Group: Members Posts: 99 Joined: 26-July 10 From: Gilbert, AZ Member No.: 11,979 Region Association: Southwest Region ![]() |
I know there may not be a lot of people on here who will be interested in this for their car, but it will be nice to have more options for people who want more power, and a modern shifting mid-engine transaxle. These pictures are of a 6 speed version, but the 5 speed will use the same adapter plate and flywheel.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i180.photobucket.com-11979-1280185725.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i180.photobucket.com-11979-1280185729.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i180.photobucket.com-11979-1280185731.3.jpg) |
charliew |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,363 Joined: 31-July 07 From: Crawford, TX. Member No.: 7,958 ![]() |
Twin scroll, will you be able to use a factory header? It also looks like the motor cradle will allow a fatter oil pan but with the stuff you are doing it will probably be a dry sump right?
precisionchassis |
Twin scroll, will you be able to use a factory header? It also looks like the motor cradle will allow a fatter oil pan but with the stuff you are doing it will probably be a dry sump right? I'm not going to be using the factory manifolds. The factory exhaust is designed to run along the right side of the motor which is where the Boxster has it's shifter cables and linkage. I will be making custom stainless steel headers that will dump into the turbo on the left side of the transaxle. I'll have some pictures up in a few days of the exhaust. No dry sump on this car (too expensive to justify) |
Lo-Fi Version | Time is now: 19th April 2025 - 01:18 PM |
