2.7L, So why is 2.7L the motor to avoid? |
qa1142 |
Aug 28 2010, 12:05 PM
Whiplash Group: Members Posts: 1,514 Joined: 1-June 04 From: Lake Zurich, Illinois Member No.: 2,140 |
If someone is going to start looking for a 6 to build what do you want and what do you want to avoid?
2.2 2.4 2.7 3.0 3.2 (IMG:style_emoticons/default/popcorn[1].gif) |
J P Stein |
Aug 28 2010, 03:46 PM
The 993 Divilar, full thread, coated studs are the way to go. Steel studs come loose due to uneven expansion rates......no big deal if you don't mind retorquing the heads a few times till the aluminum is done coldworking (if you don't know what type of coldworking I'm speaking of, ask)......this assumes case savers have been installed.
The 2.7L gets a bad rap. All the motors have weak points and need to be rebuilt to adress these issues. With a mag case just keep it cool and it'll live. That said, if I was gonna do it again I'd use a 3.0L unless I was building to class. |
Lo-Fi Version | Time is now: 28th September 2024 - 12:47 PM |
