> Home made tools, Show us yours
Bartlett 914
post Jan 8 2009, 09:21 AM
We all do it. We sometimes need a tool for a special use. It sometimes makes the difference in how well a job comes out Earlier this year, just for the heck of it, I removed the shaft from the bushings in an old trailing arm. I ended up using heat. I did get it out but what a an awful stinky mess! Yesterday Glenn (gms) stopped by with 2 trailing arms he was cleaning up. He wanted to know if I had a press for the job. With a little scrap metal some machining and welding we came up with a simple tool to remove the shaft. Here are a couple pictures of what we came up with. The tool worked really nice. I think if wanted, this would also work with the trailing arm in the car.
So how about posting some of the special tools you have made.
Dr Evil
post Aug 28 2010, 07:03 PM
Send me your transmission!
That looks dangerous (IMG:style_emoticons/default/blink.gif)
Bartlett 914   Home made tools   Jan 8 2009, 09:21 AM
URY914   I kinda like by engine crossbar wheels. It's n...   Jan 8 2009, 09:44 AM
Bartlett 914   I kinda like by engine crossbar wheels. It's ...   Jan 8 2009, 09:52 AM
marks914   Here is my version of the engine installation tool...   Jan 8 2009, 10:48 AM
Dr Evil   I removed my /6 and tranny together last night and...   Jan 8 2009, 10:56 AM
aircooledtechguy   Here's a couple things: The first is a super ...   Jan 8 2009, 11:13 AM
Bartlett 914   Here's a couple things: The first is a super...   Jan 8 2009, 11:22 AM
aircooledtechguy   I like your soda blaster. For cleaning the carbur...   Jan 8 2009, 01:50 PM
SGB   Yeah Nate, that extended plug socket is good. I d...   Jan 8 2009, 11:27 AM
Jeff Bowlsby   My D-Jet break-out box:   Jan 8 2009, 02:30 PM
Bartlett 914   My Brake bleeder. Probably the simplest of tools b...   Jan 8 2009, 03:19 PM
HAM Inc   Those are some neat tools! I really like the a...   Jan 8 2009, 04:06 PM
scotty b   My English wheel and my shrinker / stretcher I con...   Jan 8 2009, 06:54 PM
r_towle   B)-->
QUOTE(scotty b @ J...   Jan 8 2009, 08:12 PM
scotty b   some guy on E-bay seveal years ago. I really don...   Jan 8 2009, 08:17 PM
URY914   I made an extension for my floor jack. When I jack...   Jan 8 2009, 07:09 PM
URY914   I welded a old socket on the bottom of it to go in...   Jan 8 2009, 07:10 PM
URY914   I also get comments on the jack stand blocks. Who ...   Jan 8 2009, 07:12 PM
URY914   I build this tool box/welding cart too...   Jan 8 2009, 07:16 PM
URY914   The frame in made of scrap Unistrut steel from a j...   Jan 8 2009, 07:19 PM
URY914   I found these bad boys at a auto show and really w...   Jan 8 2009, 07:23 PM
smontanaro   Can we just skip the obligatory waiting period and...   Jan 8 2009, 07:37 PM
Todd Enlund   Can we just skip the obligatory waiting period an...   Jan 8 2009, 07:59 PM
911quest   Here is my work in progress a P258c for seting pin...   Jan 8 2009, 07:45 PM
Dr Evil   Here is my work in progress a P258c for seting pi...   Jan 8 2009, 07:46 PM
Zimms   Here is my work in progress a P258c for seting pi...   Jan 9 2009, 08:36 PM
911quest   Here is my work in progress a P258c for seting p...   Jan 10 2009, 09:31 PM
Zimms   [quote name='Zimms' post='1119775' date='Jan 9 20...   Jan 10 2009, 11:22 PM
r_towle   I want a plasma cutter...my head hurts thinking ab...   Jan 8 2009, 08:20 PM
scotty b   Yeah most likely overkill as I used 3/8 plate for ...   Jan 8 2009, 08:24 PM
RJMII   http://inlinethumb26.webshots.com/43161/2593686280...   Jan 8 2009, 11:53 PM
wertygrog   here's a super flat 22mm wrench for tensioning...   Jan 8 2009, 11:57 PM
zambezi   Heres an engine stand I built for storing and runn...   Jan 9 2009, 01:18 AM
Bartlett 914   Heres an engine stand I built for storing and run...   Jan 9 2009, 08:51 AM
zambezi   Heres an engine stand I built for storing and ru...   Jan 11 2009, 12:26 AM
michelko   My Engine Test stand and the tool to check fuel...   Jan 9 2009, 08:58 AM
Todd Enlund   and the tool to check fuellevel in zenith carbs ...   Jan 9 2009, 12:50 PM
aircooledtechguy   Here's my engine run stand and the starter box...   Jan 9 2009, 11:25 AM
andys   I've got several custom jigs and fixtures, but...   Jan 9 2009, 02:56 PM
roadster fan   I've got several custom jigs and fixtures, bu...   Jan 9 2009, 04:16 PM
MrKona   Here's my transaxle driveshaft holder tool. Ke...   Jan 9 2009, 03:19 PM
roadster fan   Here is one that I made after having to remove the...   Jan 9 2009, 04:37 PM
914dave   Here's the rotisserie pix's   Jan 9 2009, 05:15 PM
J P Stein   Wanna check backlash on the R&P of your 901? H...   Jan 9 2009, 07:34 PM
MrKona   Wanna check backlash on the R&P of your 901? ...   Jan 9 2009, 10:23 PM
J P Stein   I like the backlash measurement set up. Do you ...   Jan 10 2009, 10:47 AM
carr914   This thread would not be complete without FourBlad...   Jan 9 2009, 09:32 PM
sean_v8_914   suspension bushing reamer   Jan 10 2009, 10:09 AM
rick 918-S   I made these for doing large deep shrinks. You sli...   Jan 10 2009, 01:57 PM
rick 918-S   Here is the result or close to it.   Jan 10 2009, 01:57 PM
McMark   Revival! I found a tool I made awhile ago. 9...   Jan 19 2009, 09:53 PM
highways   Here's my favorite 'found object'. My ...   Jan 20 2009, 03:49 AM
Dr Evil   Here's my favorite 'found object'. My...   Jan 28 2009, 04:46 PM
McMark   That's a cool kit!   Jan 20 2009, 08:46 PM
URY914   No, it's a TOOL kit.   Jan 20 2009, 09:23 PM
MrKona   Here's my home made blasting cabinet. I just f...   Jan 28 2009, 01:13 AM
Todd Enlund   Here's my home made blasting cabinet. I just ...   Feb 1 2009, 11:35 AM
cwpeden   I made my own blasting cabinet too and used my sho...   Jan 28 2009, 01:41 AM
scotty b   Yeah you really can't beat Thompsons prices bu...   Jan 28 2009, 06:44 PM
rick 918-S   I'm not sure if you would classify 2" mas...   Jan 30 2009, 08:39 AM
highways   I couldnt resist this deal on the cigars, but be...   Jan 30 2009, 06:51 PM
zig-n-zag   tranny nut buster.... http://i631.photobucket.com/...   Jan 31 2009, 07:48 PM
majkos   I'm suprise no one made a Engine Head Sensor t...   Feb 1 2009, 09:59 AM
majkos   Simple 13mm socket, 914 jack handle, cut at a ...   Feb 1 2009, 10:20 AM
Sleepin   ......and I am missing your Superbowl party.... :W...   Feb 1 2009, 11:15 AM
Gint   You've never been to Kevin's?!?! ...   Feb 1 2009, 11:22 AM
majkos   You've never been to Kevin's?!?! ...   Feb 1 2009, 02:16 PM
Wilhelm   [size=5]Ball Joint Remover [center]So I don...   Feb 2 2009, 10:11 PM
McMark   Nice work.   Feb 3 2009, 12:49 AM
Racer Chris   Delrin rear bushing cutting tools Top: Sleeve th...   Feb 5 2009, 09:23 AM
larss   Rear boot torsion bar tool Made this tool for fit...   Sep 22 2009, 01:15 AM
charliew   I don't remember where I saw it but the fiero ...   Sep 22 2009, 08:24 AM
jimkelly   bearing removal tool - not mine see thread http...   Apr 28 2010, 07:21 AM
McMark   Made another tool today. This piece fits tightly ...   Jul 28 2010, 02:01 PM
rdauenhauer   Here is one that is surprisingly simple but I find...   Jul 30 2010, 09:35 PM
rdauenhauer   here is THE tool for unlocking the rear boot :D ...   Jul 30 2010, 09:37 PM
Jeff Bowlsby   here is THE tool for unlocking the rear boot :D ...   Aug 12 2010, 01:07 PM
charliew   here is THE tool for unlocking the rear boot :D...   Aug 13 2010, 05:34 PM
charliew   A picture of you using that tool would be interest...   Jul 31 2010, 01:05 PM
larss   Handle made when fitting the rear window, one in e...   Aug 12 2010, 02:50 AM
McMark   :lol4: Love it, Lars! That's awesome.   Aug 12 2010, 11:22 AM
Richard Casto   :lol4: Love it, Lars! That's awesome. ...   Aug 12 2010, 01:13 PM
Phoenix-MN   Let's kick it up a notch This isn't 914 ...   Aug 12 2010, 06:23 PM
charliew   That is neat but it would take me three days to bu...   Aug 13 2010, 05:27 PM
Bartlett 914   That is neat but it would take me three days to b...   Aug 13 2010, 05:33 PM
rick 918-S   That is neat but it would take me three days to ...   Aug 14 2010, 02:42 PM
Phoenix-MN   That is neat but it would take me three days to b...   Aug 14 2010, 02:31 PM
qa1142   [quote name='charliew' post='1356147' date='Aug 1...   Aug 14 2010, 02:40 PM
rudedude   I'd even pay you something for your time :tro...   Aug 14 2010, 03:00 PM
qa1142   that is the $25 I would even add a paypal fe...   Aug 14 2010, 03:06 PM
charliew   I would think 300.00-500.00 might cover the labor   Aug 14 2010, 03:09 PM
Phoenix-MN   I would think 300.00-500.00 might cover the labo...   Aug 14 2010, 05:15 PM
qa1142   [quote name='charliew' post='1356452' date='Aug 1...   Aug 14 2010, 05:22 PM
sixnotfour   Towing aid without removing axles.   Aug 28 2010, 05:56 PM
Dr Evil   That looks dangerous :blink:   Aug 28 2010, 07:03 PM
John   First pic shows: 914 Rotisserie Engine stand My...   Aug 28 2010, 09:06 PM
rick 918-S   I had a very rusty caliper I made this clamp with ...   Sep 21 2010, 10:43 PM
rick 918-S   :)   Sep 21 2010, 10:44 PM
rick 918-S   :)   Sep 21 2010, 10:46 PM
rick 918-S   :)   Sep 21 2010, 10:48 PM
27 User(s) are reading this topic (27 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 27th December 2024 - 06:58 PM
