Bartlett 914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,216 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest ![]() |
I am about to do a clutch change on my 2.0 4cyl. Recently on one of Ripper911 threads, Slits posted a link showing the specs for the flywheel. I think that sheet is for the 6. I found the same drawing in the 6 workshop manual. Problem is I have 3 flywheels and according to that sheet, all are worn out. The sheet shows 11mm to be the wear limit on Dimension "C". Mine are all less than 8mm. I have doubts that all have been worked on that many times. Is there a different specifications sheet for a 4 cyl flywheel? Here is a copy of the one I have:
bobhasissues |
seemingly endless issues with my 914 ![]() ![]() Group: Members Posts: 218 Joined: 13-February 07 From: Chicagoland Member No.: 7,532 Region Association: None ![]() |
Have a PDF of it on my home computer. Will forward it tonight if you don't get it sooner.
Lo-Fi Version | Time is now: 20th June 2024 - 06:16 AM |
