> Subaru Engine w/Boxster transaxle, Perfect fix for 914???
precisionchassis
post Jul 26 2010, 05:08 PM
I know there may not be a lot of people on here who will be interested in this for their car, but it will be nice to have more options for people who want more power, and a modern shifting mid-engine transaxle. These pictures are of a 6 speed version, but the 5 speed will use the same adapter plate and flywheel.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i180.photobucket.com-11979-1280185725.1.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i180.photobucket.com-11979-1280185729.2.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i180.photobucket.com-11979-1280185731.3.jpg)
precisionchassis
post Sep 3 2010, 07:59 PM
I finally got the exhaust finished today. I'm pretty happy with the way it came out. I still need to add two double slip joints in between the cylinder banks, some wastegate dump supports, and a couple of O2 bungs, but other than that, it's done. This first system is only 304 SS but I made sure to carefully purge everything, and all of the welds are full penetration welds rather than the standard "automotive style" welds so it will have the best possible chance of surviving. Also, the turbo is supported by a 1/4" thick plate bracket so the actual exhaust tubing isn't holding any weight other than it's own. If the 304 doesn't survive, then I will do the second set in 321 and see how long that lasts.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i180.photobucket.com-11979-1283565551.1.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i180.photobucket.com-11979-1283565551.2.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i180.photobucket.com-11979-1283565552.3.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i180.photobucket.com-11979-1283565552.4.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i180.photobucket.com-11979-1283565552.5.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i180.photobucket.com-11979-1283565552.6.jpg)
precisionchassis   Subaru Engine w/Boxster transaxle   Jul 26 2010, 05:08 PM
daveyboybadion   That's cool, are you selling the adapter?...da...   Jul 26 2010, 05:21 PM
precisionchassis   That's cool, are you selling the adapter?...d...   Jul 26 2010, 06:22 PM
jimkelly   the shoe prints on the wall - big distraction : )   Jul 26 2010, 05:25 PM
andys   Did you have to notch the bellhousing to get the s...   Jul 26 2010, 05:36 PM
precisionchassis   Did you have to notch the bellhousing to get the ...   Jul 26 2010, 05:42 PM
charliew   I wonder what is the torque specs for the boxter 6...   Jul 26 2010, 08:07 PM
BIGKAT_83   Great work!! I guess its time to start lo...   Jul 27 2010, 08:43 AM
tommy914   will this use the cable shifter from the Boxster? ...   Jul 27 2010, 08:52 AM
precisionchassis   will this use the cable shifter from the Boxster?...   Jul 27 2010, 01:01 PM
budman5201   Hey are you making this adaptor? I am VERY interes...   Jul 27 2010, 04:19 PM
precisionchassis   Hey are you making this adaptor? I am VERY intere...   Jul 27 2010, 04:28 PM
budman5201   Hey are you making this adaptor? I am VERY inter...   Jul 27 2010, 04:52 PM
precisionchassis   [quote name='precisionchassis' post='1348743' dat...   Jul 27 2010, 05:08 PM
Zaney   Is this your 911 SVX engine swap? If so, AWESOME...   Jul 27 2010, 06:29 PM
precisionchassis   Is this your 911 SVX engine swap? If so, AWESOM...   Jul 27 2010, 07:09 PM
precisionchassis   New body work mocked-up on test car... http://www...   Jul 29 2010, 03:54 PM
rickthejetman   about how much does a boxter trans cost? 5spd or 6...   Jul 29 2010, 04:12 PM
precisionchassis   about how much does a boxter trans cost? 5spd or ...   Jul 29 2010, 05:07 PM
andys   A good 5 speed is about $1500, and a 6 spee...   Jul 29 2010, 05:20 PM
Jake Raby   about how much does a boxter trans cost? 5spd or...   Aug 12 2010, 12:07 AM
precisionchassis   I just pulled the stock M96 engine out of the dono...   Aug 7 2010, 10:41 PM
charliew   I think because of the weight of the 914 the highe...   Aug 9 2010, 07:01 PM
precisionchassis   The gear ratios between the STI and Boxster 6 spee...   Aug 9 2010, 11:42 PM
charliew   I agree, it sounds like the boxter gearing is bett...   Aug 10 2010, 03:16 PM
atsealevel914   :popcorn: :popcorn: :popcorn:   Aug 11 2010, 08:13 PM
DBCooper   Is part of the plan to put Subaru engines in all t...   Aug 11 2010, 08:53 PM
precisionchassis   Is part of the plan to put Subaru engines in all ...   Aug 12 2010, 03:55 PM
DBCooper   Is part of the plan to put Subaru engines in all...   Aug 12 2010, 04:08 PM
precisionchassis   [quote name='precisionchassis' post='1355617' dat...   Aug 12 2010, 04:34 PM
Jake Raby   [quote name='precisionchassis' post='1355617' dat...   Aug 12 2010, 09:04 PM
charliew   A stock 2.5 04 sti is about 240-260hp at the 4 whe...   Aug 12 2010, 04:24 PM
DBCooper   Actually Jake would probably make a great suby mo...   Aug 12 2010, 05:20 PM
DBCooper   Don't know about that, Jake, I started with a ...   Aug 13 2010, 04:34 PM
RJMII   :stfu: about jake already. You're reading anno...   Aug 13 2010, 06:59 PM
Jake Raby   Nothing is currently annoying me, not even DB.. Th...   Aug 14 2010, 03:06 AM
DBCooper   Wow, could I be mistaken? Jake, I'm used to h...   Aug 14 2010, 04:43 AM
jimkelly   the sandbox exists for a reason. that said - i am...   Aug 14 2010, 06:16 AM
76-914   :popcorn: sans the bickering. this is good stuff; ...   Aug 14 2010, 11:16 AM
JRust   Love to see the work you are doing with the adapte...   Aug 14 2010, 11:43 AM
precisionchassis   Love to see the work you are doing with the adapt...   Aug 14 2010, 11:50 AM
Mueller   Love to see the work you are doing with the adap...   Aug 14 2010, 12:16 PM
JRust   Love to see the work you are doing with the adap...   Aug 14 2010, 07:34 PM
RJMII   If I were to send you a solidworks drawing of an e...   Aug 14 2010, 12:43 PM
precisionchassis   If I were to send you a solidworks drawing of an ...   Aug 14 2010, 02:04 PM
RJMII   If I were to send you a solidworks drawing of an...   Aug 14 2010, 03:03 PM
precisionchassis   Prototype motor mount/cradle is finished. It mount...   Aug 14 2010, 05:37 PM
qa1142   Now, can you make one for 914's :popcorn:   Aug 14 2010, 06:59 PM
RJMII   That really does look like it belongs there. :)   Aug 14 2010, 06:49 PM
precisionchassis   Yeah, the 914 will be next.   Aug 14 2010, 07:02 PM
okieflyr   That is a cool conversion. But now I'm going t...   Aug 14 2010, 08:20 PM
jimkelly   sweet cradle : ) love all the photos of the boxst...   Aug 15 2010, 07:53 AM
GS Guy   Nice work - but make sure it all fits the EZ30R to...   Aug 15 2010, 08:38 AM
budman5201   Nice work - but make sure it all fits the EZ30R t...   Aug 15 2010, 12:43 PM
RJMII   The boxster S six speed is STOUT. :) It's t...   Aug 15 2010, 09:56 AM
Dr Evil   Wow am I thankful. I was wondering what I was goin...   Aug 15 2010, 04:40 PM
charliew   When you pull the pan on the suby motor check the ...   Aug 16 2010, 04:16 PM
wittmer25   When you pull the pan on the suby motor check the...   Aug 23 2010, 11:58 AM
precisionchassis   Turbo and supporting pieces... http://www.914worl...   Aug 25 2010, 04:06 AM
Phoenix 914-6GT   Wow.... you do some very nice work and use choice ...   Aug 25 2010, 01:42 PM
charliew   Twin scroll, will you be able to use a factory hea...   Aug 26 2010, 03:44 PM
precisionchassis   Twin scroll, will you be able to use a factory he...   Aug 26 2010, 05:30 PM
precisionchassis   Started on the wiring harness tonight. Here is the...   Sep 2 2010, 02:33 AM
precisionchassis   I finally got the exhaust finished today. I'm ...   Sep 3 2010, 07:59 PM
Zaney   I finally got the exhaust finished today. I'm...   Sep 4 2010, 09:15 PM
Rotary'14   :blink: :drooley: :drooley: That's a work ...   Sep 3 2010, 08:03 PM
charliew   The welds look good. Do you think the long tubes w...   Sep 3 2010, 09:23 PM
precisionchassis   The welds look good. Do you think the long tubes ...   Sep 4 2010, 09:37 AM
ottox914   The welds look good. Do you think the long tubes ...   Sep 5 2010, 06:58 AM
Andyrew   That is fuckin awesome... Seriously.   Sep 3 2010, 10:31 PM
kg6dxn   That is fuckin awesome... Seriously. :agree:...   Sep 3 2010, 11:12 PM
Britain Smith   That looks fantasic. Where did you get the flange...   Sep 3 2010, 11:23 PM
precisionchassis   That looks fantasic. Where did you get the flang...   Sep 4 2010, 09:40 AM
bryanc   Sweet!!! Is that my old car? One of ...   Sep 4 2010, 10:04 AM
precisionchassis   Sweet!!! Is that my old car? One of...   Sep 4 2010, 10:08 AM
bryanc   Sweet!!! Is that my old car? One o...   Sep 4 2010, 10:13 AM
Dr Evil   I am awed by this build. One thing that I notice, ...   Sep 5 2010, 08:44 AM
roadster fan   One thing that I notice, though, is that your POP...   Sep 5 2010, 02:37 PM
ottox914   I am awed by this build. One thing that I notice,...   Sep 6 2010, 06:54 AM
Dr Evil   Blah blah, I was typing on my iPod. It is not easy...   Sep 5 2010, 06:31 PM
precisionchassis   To answer your question, Yes, I do plan on heat wr...   Sep 5 2010, 10:54 PM
precisionchassis   oh, and yes, I am keeping very detailed notes on e...   Sep 5 2010, 10:55 PM
precisionchassis   The wiring harness has been reduced to only what i...   Sep 9 2010, 05:37 PM
precisionchassis   I got the first round of primer sprayed on the pro...   Sep 14 2010, 02:39 AM
jimkelly   thanks for keepin the pics coming : )   Sep 14 2010, 06:33 AM
Britain Smith   Looks cool. Did you mold the whole thing or adapt...   Sep 14 2010, 10:39 AM
precisionchassis   Looks cool. Did you mold the whole thing or adap...   Sep 14 2010, 01:22 PM
Britain Smith   Yep, been there, done that. It looks good though....   Sep 14 2010, 03:32 PM
bryanc   Any updates??? :)   Oct 9 2010, 11:13 AM
precisionchassis   Quick update... The plan was to finish the interc...   Nov 4 2010, 01:27 PM
Boxsterund914   Are those rear flares something you made? If not, ...   Nov 10 2010, 03:34 PM
precisionchassis   A.I.R. makes the flares, but I have to warn you......   Nov 10 2010, 03:49 PM
Hontec   Beautiful work!!! :trophy:   Nov 10 2010, 04:04 PM
precisionchassis   Intercooler plumbing finished. That's it. Only...   Nov 13 2010, 07:21 PM
precisionchassis   Air-Jacks added... http://www.914world.com/bbs2/u...   Dec 2 2010, 08:01 PM
Andyrew   Air jacks are so cool!   Dec 2 2010, 10:43 PM
geniusanthony   I think your doing a great job on this build. The ...   Dec 3 2010, 01:06 AM
precisionchassis   So one of the things I have been dreading ever sin...   Dec 14 2010, 07:01 PM
precisionchassis   Plumbed the air-jacks and started on the electroni...   Dec 30 2010, 03:46 AM
Jeroen   awesome fabwork (as usual)   Dec 30 2010, 08:22 AM
- Lo-Fi Version Time is now: 19th April 2025 - 01:16 PM
