tomh |
Member ![]() ![]() Group: Members Posts: 322 Joined: 28-February 10 From: san jose Member No.: 11,412 Region Association: None ![]() |
I think am ready now to add sway bars to my 72.
For street use which is the best way to go? Should I do front and rear or start with the rear first and see how it handels? Is this something I could do in my garage? Give me a breif run down on the install process. |
tradisrad |
Senior Member ![]() ![]() ![]() Group: Members Posts: 985 Joined: 11-September 06 From: San Mateo, CA Member No.: 6,815 Region Association: Northern California ![]() |
Lots of guys don't use a rear sway bar.
If you car does not have a factory sway bar then you will need to cut and drill. I am not sure, but you may need to remove the gas tank. Check this link: http://www.pelicanparts.com/techarticles/9...ont_swaybar.htm |
tomh |
Lots of guys don't use a rear sway bar. If you car does not have a factory sway bar then you will need to cut and drill. I am not sure, but you may need to remove the gas tank. Check this link: http://www.pelicanparts.com/techarticles/9...ont_swaybar.htm so whats the exact differnce between a through the body v. under body front bar as far as performance? |
ConeDodger |
Apex killer! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,631 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California ![]() ![]() |
Lots of guys don't use a rear sway bar. If you car does not have a factory sway bar then you will need to cut and drill. I am not sure, but you may need to remove the gas tank. Check this link: http://www.pelicanparts.com/techarticles/9...ont_swaybar.htm so whats the exact differnce between a through the body v. under body front bar as far as performance? First of all, I can't believe Porsche/VW made a single one of these cars without a swaybar. The difference is absolutely astonishing. Second, don't you dare put the rear on first and drive the car. If you do, please warn me so I can stay off of the roads you drive. Yes, do it. Best modification you can do to a non-swaybar car. Do front first, rear is optional but if you have both go for it. Be sure to get the rear sway bar shock bolts when you buy a rear bar. They are as hard to find as real sixes. It makes no difference whether you go through the body or under. Stock was through. edit: I just noticed you're in San Jose. Rich Bontempi will have the shock bolts. You will remember forever what he charged you for them, but he is a great guy and he has them. Something to be said for not having to look for them forever! |
tomh |
Lots of guys don't use a rear sway bar. If you car does not have a factory sway bar then you will need to cut and drill. I am not sure, but you may need to remove the gas tank. Check this link: http://www.pelicanparts.com/techarticles/9...ont_swaybar.htm so whats the exact differnce between a through the body v. under body front bar as far as performance? First of all, I can't believe Porsche/VW made a single one of these cars without a swaybar. The difference is absolutely astonishing. Second, don't you dare put the rear on first and drive the car. If you do, please warn me so I can stay off of the roads you drive. Yes, do it. Best modification you can do to a non-swaybar car. Do front first, rear is optional but if you have both go for it. Be sure to get the rear sway bar shock bolts when you buy a rear bar. They are as hard to find as real sixes. It makes no difference whether you go through the body or under. Stock was through. so the weltmiser bar with the adapter kit so I do not have to go through the body would be the way to go as far as ease of install but wouldent be the "pure" way to do it. I have tryed to keep with the spiret of corretness however I do not like cutting up my car. |
Lo-Fi Version | Time is now: 26th June 2024 - 08:16 AM |
