NC_Colfax |
Member ![]() ![]() Group: Members Posts: 130 Joined: 26-July 10 From: North Carolina Member No.: 11,982 Region Association: South East States ![]() |
OK I just brought my 914
It's a 73 that has been converted to electronic ignition and a MSD box and MSD coil. The PO wired in a bypass start switch(button) that was used to start the car. Well car had been doing fine but last couple days you hit the button and all you get is a click sound. I can see it pull voltage on the voltmeter in the center console. I installed a new high dollar battery in case I was not getting enough voltage....still nothing. Were do I start?? Ground....Wiring...Starter. I really want to drive to car while we have good warm weather. Thanks 914 World |
john rogers |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,525 Joined: 4-March 03 From: Chula Vista CA Member No.: 391 ![]() |
I would do the following:
- Check the switch resistance after unhooking the wires to make sure it has 0 resistance when in start position. - Check where the wires for the switch are wired into the electrical system to make sure they have not started coming apart. - Clean the switch terminals and lugs or how ever the wires are hooked to the switch. - Check the wires at the starter, the large one that goes on the lug at the top that is nearly impossible to see. Clean the lug and wire connector. - Check the huge wire from the battery that is bolted on, remove it and clean the lug and wire brush the stud. - Check the ground strap from the tranny to the body, clean as necessary. - Check both lugs at the batt and clean the lugs and the lug where the batt ground strap attaches to the body. - Pull the starter to have it tested. You can test the starting after each step which is what I would do. |
Lo-Fi Version | Time is now: 26th June 2024 - 08:40 AM |
