911R style tail lamps for the 914, I found the info on who made mine |
campbellcj |
Sep 5 2010, 04:56 PM
I can't Re Member Group: Members Posts: 4,588 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
There was a thread on this not too long ago but I searched and couldn't find it.
I just pulled mine out of a box -- getting ready to work on the car some more -- and I noticed this marking on the back side of the fiberglass. (IMG:style_emoticons/default/smile.gif) No idea whether he is still in business or still making these parts. Mike Swanson AR Concepts ar_concepts@hotmail.com (818) 470-5700 Attached thumbnail(s) |
campbellcj |
Sep 6 2010, 10:44 PM
I got the lamp assemblies wired-up today and pretty much figured-out everything. I had some trouble sourcing the 18W festoon bulbs locally so I'm going to try LED replacements for the brake lights -- if those work as intended they should be extremely bright and quick to respond. I'm using the smaller 10W bulbs for initial testing.
The other setback is that I just realized my running/parking lights are completely out (no power). They worked last time I fiddled with them to install the euro front turn signal kits, so I bet something came loose up front. It is not a fuse or switch as far as I can tell. Here are the Hella lamps wired-up. They will plug right into the factory wiring, although I'll have to split the single ground per side into two per side. (IMG:http://www.914world.com/bbs2/uploads_offsite/farm5.static.flickr.com-21-1283834681.1.jpg) 911R Hella tail lamps by cjcam, on Flickr |
Lo-Fi Version | Time is now: 22nd November 2024 - 10:38 PM |
