strawman |
Senior Member ![]() ![]() ![]() Group: Members Posts: 888 Joined: 25-January 08 From: Los Osos, CA Member No.: 8,624 Region Association: Central California ![]() ![]() |
I've searched but can't seem to find definitive answers about what size and specs for the coolant hoses for my turbo Subaru engined conversion. I'm interested in real world experience from others that have running water-cooled conversions. Based on my research of this site, I've decided to follow most conversion guys' use of rubber hoses in lieu of SS or aluminum pipes for the long run between the engine and radiator -- run in the recesses along the bottom of the chassis.
Renegade Hybrids sells Gates Green Stripe (or equivalent) hose, in 11' of 1-1/4" ID and 13' of 1" ID for -- including clamps -- for $100. According to their website, they recommend 1-1/4" I.D. from lower radiator to pump and 1" I.D. from upper radiator to the thermostat housing. Those sizes provided by Renegade would require that I use adaptors for both ends on each hose(engine and radiator), so I've searched the usual suspects like Ebay, NAPA, Rock Auto and marine suppliers for bulk heavy-duty 1-1/2" ID hoses -- but my head is spinning from all the options. Is a "hardwall" rubber hose required (the type with wire reinforcement) for the engine-radiator hose? If so, marine exhaust hose seems to sell for ~$5.00 to $8.00 per foot on Ebay. It seems like the suction side should be beefier so that it doesn't collapse when hot, but maybe that is not important, so a two-ply polyester-reinforced hose might suffice. Any opinions from you Chevy V8, Subaru or other guys? I'm also looking for 25' of 3/4" ID heater hose for my water-air intercooler setup, as my heat exchanger is mounted in front of the radiator. Again, is hardwall rubber hose required, or would any high-quality two-ply polyester-reinforced hose work? Thanks for your opinions! Geoff |
budman5201 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 595 Joined: 1-April 07 From: tempe, az Member No.: 7,635 ![]() |
i have used larger sizes and had cooling problems. When i just went with Renegades sizes, no matter which Subaru engine i have done. ej25 n/A 165 hp, ej20 Turbo 300 hp, or ez30R 250 hp N/A.... Never had problems.
Think it has to do with smaller forces the water to the radiator and larger makes it an easier path back to the engine. I am running Marine grade reinforced hoses exactly the same sizes as Renegades and bought renegades reducers to/from the engine to make them fit the subaru engine. (obviously this was a LONG time before i knew how to weld aluminum. Today i would of just made them myself. |
Lo-Fi Version | Time is now: 19th April 2025 - 01:16 PM |
