Rear Trunk Spring Install |
wit61 |
Sep 7 2010, 07:23 PM
Newbie Group: Members Posts: 28 Joined: 20-June 06 From: PA Member No.: 6,269 |
I have tried the search function to no avail. Does anyone have the suggested steps for re-installing the two springs (stressed metal rods) that keep the trunk up when open ?? If I missed a thread on this, please point me in the right direction. Thanks
73 914 70 911E 70 911T Targa If you go flying back into the past and you see someone else flying forward into the future, it is probably best to avoid eye contact.... www.classicvelocity.com |
dr914@autoatlanta.com |
Sep 8 2010, 09:10 AM
914 Guru Group: Members Posts: 8,092 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
It is actually easy with a 10 mm box wrench and a craftsman 1/2 inch breaker bar with the hole in the handle notched to a "c" simply start the spring forward with the box wrench then grab it with the handle of the breaker bar and ease it around the roller. There is a diagram and a procedure in the "Tech Tips 700"
I have tried the search function to no avail. Does anyone have the suggested steps for re-installing the two springs (stressed metal rods) that keep the trunk up when open ?? If I missed a thread on this, please point me in the right direction. Thanks 73 914 70 911E 70 911T Targa If you go flying back into the past and you see someone else flying forward into the future, it is probably best to avoid eye contact.... www.classicvelocity.com |
Lo-Fi Version | Time is now: 31st October 2024 - 07:31 PM |
