ChrisFoley |
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,937 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None ![]() ![]() |
I was tired of the axle shafts hanging down on a car with the engine removed a long time ago.
I've used bungees, coat hangers, tie downs, etc. to hold them up out of the way while crawling about under the car. Its even worse when you have to move the car and the halfshafts bang around, sometimes jamming a CV joint. Some time ago I came up with the idea of using a 2 ft. piece of cardboard tube over the inner CVs to keep them together but the tube rolls off to one side quickly and one axle falls out. Its only a minor irritation but with the number of cars we have at the shop which are engine-less, often needing to be pushed around from one area to another, I wanted a better solution. So here it is: ![]() The bracket bolts to the rear trans mounts, and the flange/tube assembly acts like an open diff. The flanges will have bolt holes for 3 different CV sizes often used on 914s. ![]() |
Bruce Hinds |
V-8 madness ![]() ![]() ![]() Group: Members Posts: 733 Joined: 27-December 06 From: Port Orchard, WA Member No.: 7,391 Region Association: Pacific Northwest ![]() |
doesn't look like the right side will rotate... how does the car roll? (IMG:style_emoticons/default/idea.gif)
Lo-Fi Version | Time is now: 26th June 2024 - 08:14 AM |
