weird_looking_cactus |
Cactus ![]() ![]() Group: Members Posts: 225 Joined: 16-February 04 From: St, George UT Member No.: 1,660 ![]() |
When I had the car running and was able to drive it the car, it would not shift into second gear. It had a pushing filling on it when I would try to go into that gear. Also even though I have the clutch all the way in and changing gears like from reverse to first it would make a big grinding noise but only once in a while. So Im thinking I need to tighten my cable to stop the grinding noise. But I have no clue about how to fix second gear. My car is a 1975 2.0 with side shifter. Thanks for those who help.
ein 6er |
Senior Member ![]() ![]() ![]() Group: Benefactors Posts: 1,115 Joined: 11-February 03 Member No.: 300 Region Association: None ![]() |
MAN!! sound like you've been having a hard time!!
i'm no expert. that said ..... have you checked your shift rod bushings? worn bushings and the clutch not fully engaging can make gettin gears really hard. have you changed the gear lube? don't get discourged!! doug |
Lo-Fi Version | Time is now: 25th June 2024 - 12:58 AM |
