Intermittent wiper not working |
michaelmoo |
Sep 15 2010, 04:26 AM
Member Group: Members Posts: 312 Joined: 21-May 04 From: Kennesaw, GA Member No.: 2,092 |
Ok I have the intermittent relay and a washer pump on my car. First ever thing is wired correctly and making good contact. Second, I know the order of the wiper switch: all the way down is intermittent, then off, then slow, then fast (well faster than slow…). Pulling the switch you get like 4 or 7 swipes and the pump comes on. That is how it is suppose to work.
Here is what I get: all the way down is nothing, then off, then slow, then fast (well faster than slow…). Pulling the switch I get the 4 or 7 swipes and the pump comes on. Thoughts? If the relay was bad would the 4 or 7 swipes still happen with the pump? Mike |
914Sixer |
Sep 15 2010, 06:33 AM
914 Guru Group: Members Posts: 9,040 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Pull your steering wheel and make sure all the 4 screws that hold the TS and Wiper switches are tight. Grounding for the the switch is through the screws. I can remember which one. Left bottom I think. Relay may have gone bad, I may have one you can test with.
Lo-Fi Version | Time is now: 31st December 2024 - 11:43 PM |
