Piston Problem- how to fix?, MY ENGINE DROPPED OFF THE ENGINE STAND!!! |
tornik550 |
Sep 14 2010, 09:04 PM
Senior Member Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
I have a set of KB performance 96mm pistons. I recently disassembled most of my engine. The engine was freshly rebuilt (with about 250 miles) however I was having an issue with cyl 3 so I took the engine out.
About 25 miles prior to removing the engine, I stripped the #4 spark plug hole. I replaced it with with a time-sert. I thought that I had done a good job of removing the metal fragments. Once I got the cylinders off, I realized that I missed several metal fragments. What can I do to fix the piston? Is there a DIY fix? Yes, there are some minor gouges on the cylinder wall- I am going to get it honed. Attached image(s) |
brant |
Sep 15 2010, 04:46 PM
914 Wizard Group: Members Posts: 11,771 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
I think its replacement time
I agree with Dave... I've tried to cut corners in the past and then later ended up tearing everything down to fix it the right way after the shortcut didn't work..... |
Lo-Fi Version | Time is now: 31st October 2024 - 07:23 PM |
