> Piston Problem- how to fix?, MY ENGINE DROPPED OFF THE ENGINE STAND!!!
tornik550
post Sep 14 2010, 09:04 PM
I have a set of KB performance 96mm pistons. I recently disassembled most of my engine. The engine was freshly rebuilt (with about 250 miles) however I was having an issue with cyl 3 so I took the engine out.
About 25 miles prior to removing the engine, I stripped the #4 spark plug hole. I replaced it with with a time-sert. I thought that I had done a good job of removing the metal fragments. Once I got the cylinders off, I realized that I missed several metal fragments.
What can I do to fix the piston? Is there a DIY fix? Yes, there are some minor gouges on the cylinder wall- I am going to get it honed.
VaccaRabite
post Sep 16 2010, 06:02 AM
En Garde!
If you have a local bug shop, they will have the studs you need.
Go over the engine with a fine toothed comb after you have totally gotten over it falling in the first place. You want to be looking for cracks in your heads, cylinders, and engine case. Needless to say, when you put it back together you are going to want to check compression and leak. But before you put it back together take a solid afternoon and inspect everything. Cracked crank or con rod is also possible depending how it fell. Will probably be fine, but crank failure during operation could grenade the engine.
I have owned three HF engine stands. All three worked exactly as I expected them to, though two of them were used to build a rotesserie and were heavily modified.
Zach
tornik550   Piston Problem- how to fix?   Sep 14 2010, 09:04 PM
Vacca Rabite   could you try going in with a dental pick to remov...   Sep 15 2010, 08:06 AM
RobW   Ouch.... :headbang:   Sep 15 2010, 08:09 AM
Vacca Rabite   :agree: Zach   Sep 15 2010, 08:11 AM
DNHunt   This sure has the feel of a disaster that builds f...   Sep 15 2010, 08:35 AM
charliew   Only if the new piston is havier than the old one....   Sep 15 2010, 03:56 PM
brant   I think its replacement time I agree with Dave... ...   Sep 15 2010, 04:46 PM
tornik550   I went outside and tried to pick the metal bits ou...   Sep 15 2010, 07:24 PM
ripper911   lol, sue Harbor Freight! :evilgrin: Where...   Sep 15 2010, 07:45 PM
tornik550   lol, sue Harbor Freight! :evilgrin: Where...   Sep 15 2010, 07:52 PM
ripper911   lol, sue Harbor Freight! :evilgrin: Where...   Sep 15 2010, 07:57 PM
WFG   Harbor Freight has cheep prices because it has che...   Sep 15 2010, 08:01 PM
Dr Evil   Man, I have used many of their stands without issu...   Sep 15 2010, 08:03 PM
tornik550   Man, I have used many of their stands without iss...   Sep 15 2010, 08:09 PM
tornik550   Man, I have used many of their stands without iss...   Sep 15 2010, 08:10 PM
tornik550   So does anybody know a good source for reasonably ...   Sep 15 2010, 08:13 PM
tornik550   opps   Sep 15 2010, 08:11 PM
nathansnathan   I had an engine come down once. It broke the fanho...   Sep 15 2010, 08:08 PM
plays with cars   Sorry, no help on a head stud, but I will second y...   Sep 15 2010, 09:32 PM
Krieger   How about Jake Raby or FAT Performance?   Sep 15 2010, 10:59 PM
Krieger   Two more maybes: Ottos, High Performance House-Ric...   Sep 15 2010, 11:01 PM
Vacca Rabite   If you have a local bug shop, they will have the s...   Sep 16 2010, 06:02 AM
draganc   "...two of them were used to build a rotesse...   Sep 16 2010, 10:00 AM
tornik550   Update- I searched my old emails and found that I...   Sep 16 2010, 08:09 PM
- Lo-Fi Version Time is now: 31st October 2024 - 07:24 PM
