> DAPO Pictures, Things that make you go hummmmm!!!!!!
914Sixer
post Sep 18 2010, 07:09 PM
I bought a z-green 74 and am in the process of sorting it out to run. I am replacing everything that is missing and not correct. I started sorting out the fuel injection and found the fuel pump moved to the front of the car with a piece of zip cord run through the tunnel from the rear to power the pump. All of this was mounted on the front suspension pan cover.
Wonder why this door rotted out? It is completely covered with 1/2 " carpet pad. Every surface had pad glued down including the bottom of the door where the drain holes were. Both door were done like this. Back wall had same carpet pad behind the molded wall.
70_914
post Sep 18 2010, 10:20 PM
20 years from now there will be a thread showing pictures of rusty 914's with dynamat all over them and the comments will be the same...
Just sayin'...
914Sixer   DAPO Pictures   Sep 18 2010, 07:09 PM
PanelBilly   I think the saddest part is that the DAPO thought ...   Sep 18 2010, 07:40 PM
dlee6204   Oh my... :sick:   Sep 18 2010, 08:57 PM
70_914   20 years from now there will be a thread showing p...   Sep 18 2010, 10:20 PM
bembry   Well, if the comments fit. . . .   Sep 19 2010, 03:07 AM
carr914   20 years from now there will be a thread showing ...   Sep 19 2010, 04:28 AM
worn   20 years from now there will be a thread showing...   Jan 28 2014, 03:33 PM
bulitt   [quote name='carr914' post='1372805' date='Sep 19...   Jan 29 2014, 03:40 PM
CptTripps   I know I'm digging up an old thread...but this...   Dec 17 2013, 10:44 AM
Mblizzard   Beaded lamp pull chain must meet all of the struct...   Dec 17 2013, 10:52 AM
monkeyboy   I wonder how many of us have a background in VW ow...   Dec 17 2013, 10:58 AM
930cabman   I wonder how many of us have a background in VW o...   Jun 25 2021, 01:44 PM
Steve Snyder   I wonder how many of us have a background in VW o...   Dec 17 2013, 01:11 PM
monkeyboy   exactly.   Dec 17 2013, 04:39 PM
rhodyguy   facet fuel pump mounted on the pass side engine ti...   Dec 17 2013, 06:15 PM
CptTripps   From the "Department of Redundancy Department...   Dec 18 2013, 07:13 AM
mikesmith   From the "Department of Redundancy Departmen...   Dec 18 2013, 10:43 AM
Chris H.   Wow...those need to go in the "bad parts muse...   Dec 18 2013, 07:34 AM
ripper911   I wish I would have gotten a picture of my 911...   Dec 18 2013, 02:29 PM
smj   I wish I would have gotten a picture of my 911...   Dec 18 2013, 02:52 PM
914Sixer   It is good to see the handy work of FORMER rocket ...   Dec 18 2013, 05:36 PM
CptTripps   Here's another good one. Looks like 3 attempt...   Jan 17 2014, 04:34 AM
914itis   Here's another good one. Looks like 3 attemp...   Jan 17 2014, 07:53 AM
carr914   RE: DAPO Pictures   Jan 17 2014, 07:05 AM
topatrout914   :WTF: I can't imagine why some DAPO would do t...   Jan 17 2014, 09:08 AM
Mblizzard   I think it is of greater concern to find out what ...   Jan 17 2014, 09:53 AM
toolguy   I'd imagine that was their way of lowering the...   Jan 17 2014, 10:20 AM
euro911   I found out why the 'BB's left headlight d...   Jan 26 2014, 10:43 PM
sixnotfour   More likely to raise it because of the sagging r...   Jan 26 2014, 10:46 PM
OU8AVW   Flairs?   Jan 27 2014, 05:39 AM
SirAndy   Flairs? :sick:   Jan 27 2014, 12:34 PM
euro911   RE: DAPO Pictures   Jan 27 2014, 01:14 PM
flipb   That's egregious. Real Creamsicle sans t...   Jan 27 2014, 01:17 PM
Java2570   I saw that one last night and was cracking up...   Jan 27 2014, 07:00 PM
CptTripps   Real. COA and everything. It's on eBay right n...   Jan 27 2014, 02:04 PM
Garold Shaffer   The 1972 parts car I just cut up. I bought the car...   Jan 27 2014, 08:40 PM
Old Yella   Are they orange bar badges? The 1972 parts car...   Jan 27 2014, 10:54 PM
gms   here is how you fix a broken suspension mount   Jan 27 2014, 10:13 PM
ThePaintedMan   here is how you fix a broken suspension mount ...   Jan 27 2014, 10:35 PM
Bartlett 914   here is how you fix a broken suspension mount ...   Jan 28 2014, 07:56 AM
Mike Bellis   OK, I'll post this. PO used this custom bolt s...   Jan 27 2014, 10:37 PM
McMark   I love this thread. :wub:   Jan 28 2014, 12:44 AM
OU8AVW   I'll have allot more but I'm not done putt...   Jan 28 2014, 08:33 AM
CptTripps   I'm trying to think of a way to attach those W...   Jan 28 2014, 11:09 AM
Chris H.   :agree: Look how weak the mounting point is on the...   Jan 28 2014, 03:13 PM
carr914   [quote name='carr914' post='1372805' date='Sep 19...   Jan 28 2014, 08:35 PM
Eric_Shea   So... when you add extra padding to your door pane...   Jan 29 2014, 03:33 PM
bulitt   Pedal cluster floor. layers of riveted metal, bndo...   Jan 29 2014, 04:40 PM
topatrout914   Pedal cluster floor. layers of riveted metal, bnd...   Feb 3 2014, 07:04 AM
CptTripps   Not exactly DUMB stuff...but I found some cool stu...   Feb 2 2014, 06:23 PM
vw505   Sweet.   Feb 2 2014, 10:50 PM
ThePaintedMan   Someone took the time to braze, rivet and glue in ...   Feb 3 2014, 09:35 AM
worn   Someone took the time to braze, rivet and glue in...   Feb 3 2014, 10:19 AM
76-914   Someone took the time to braze, rivet and glue i...   Feb 6 2014, 08:58 AM
Chris H.   Someone took the time to braze, rivet and glue in...   Feb 6 2014, 09:45 AM
Garold Shaffer   Typical floor repair. Tin panel riveted in with fi...   Feb 5 2014, 09:04 PM
914werke   I encountered one yesterday, car came in for F. en...   Jun 9 2021, 09:48 AM
windforfun   :WTF: :WTF: :WTF:   Jun 9 2021, 12:32 PM
pt_700   not my p.o., found on craigslist. apologies if th...   Jun 10 2021, 02:46 PM
rjames   not my p.o., found on craigslist. apologies if t...   Jun 10 2021, 03:11 PM
pt_700   let's have some more fun with this one! i...   Jun 10 2021, 04:44 PM
windforfun   Go San Jose!!! I used to live in Sant...   Jun 10 2021, 06:36 PM
AZBanks   At some point I am going to have to do something a...   Jun 10 2021, 09:18 PM
Jwjwjw   I was encouraged to add this picture here. Enj...   Jun 11 2021, 04:57 PM
Jwjwjw   Same car different location of previous work. ...   Jun 11 2021, 04:58 PM
ejm   Spent some time today helping a fairly new owner s...   Jun 12 2021, 06:27 PM
bkrantz   Spent some time today helping a fairly new owner ...   Jun 12 2021, 08:04 PM
Front yard mechanic   Spent some time today helping a fairly new owner...   Jun 12 2021, 08:50 PM
euro911   Back in the 60s, one of my brother's friends h...   Jun 25 2021, 10:45 AM
914werke   Why you ask... you got me!   Jun 25 2021, 12:41 PM
914werke   Ive got a lot more from this poor car. :(   Jun 25 2021, 12:44 PM
Root_Werks   Rich, that white 914 has some bizarre stuff going ...   Jun 25 2021, 04:00 PM
Jett   Rich, that white 914 has some bizarre stuff going...   Jun 26 2021, 09:39 AM
914werke   Thats just the tip of the iceburg :sick:   Jun 25 2021, 06:48 PM
Jett   Thats just the tip of the iceburg :sick: I like...   Jun 26 2021, 09:42 AM
Superhawk996   When I see the stuff done to these cars, I’m not...   Jun 25 2021, 09:00 PM
Jett   When I see the stuff done to these cars, I’m no...   Jun 26 2021, 09:40 AM
bkrantz   When I see the stuff done to these cars, I’m no...   Jun 26 2021, 08:02 PM
get off my lawn   When I see the stuff done to these cars, I’m no...   Jun 30 2021, 12:14 AM
930cabman   Some of this stuff is just plain scary. I guess a ...   Jun 26 2021, 08:07 AM
JeffBowlsby   Reminds of the only rear engine 914…where is tha...   Jun 26 2021, 09:50 AM
sixnotfour   Reminds of the only rear engine 914…where is th...   Jun 26 2021, 12:10 PM
930cabman   Reminds of the only rear engine 914…where is t...   Jun 26 2021, 05:33 PM
volksaddict   PO left me a couple spare Berus :shades2: Note the...   Jul 11 2021, 06:03 AM
Superhawk996   Glad I decided to do the top end! :rotfl...   Jul 11 2021, 05:16 PM
volksaddict   Liked his rtv blue too   Jul 11 2021, 06:07 AM
914werke   Bad mtr mnts? why replace them when youve got a we...   Jul 11 2021, 08:38 AM
930cabman   If you are down, just page through this thread, sh...   Jul 11 2021, 11:08 AM
cassmcentee   If you are down, just page through this thread, s...   Sep 18 2021, 05:44 AM
volksaddict   Oh yeah the oil cooler :woohoo: Wondering if someo...   Jul 11 2021, 07:36 PM
914werke   So heres one I see all sorts of variations of: Fue...   Sep 17 2021, 02:21 PM
IronHillRestorations   "Welds". Poor customer actually paid fo...   Sep 17 2021, 08:40 PM
SirAndy   "Welds", that came off with vice grips ...   Sep 17 2021, 08:45 PM
58 User(s) are reading this topic (58 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 11th March 2025 - 01:51 PM
