sawtooth |
Member ![]() ![]() Group: Members Posts: 297 Joined: 25-June 08 From: Boise, ID Member No.: 9,211 Region Association: Intermountain Region ![]() |
Wanted to start a build thread for my na suby conversion. The car is my newly acquired '73 2.0L fi. It is very clean, appearance group, 2nd owner, 88K. I currently use it as my daily driver.
![]() ![]() ![]() I want to do a suby conversion because I believe the overall package will have the performance, drivability, and dependability I'm looking for. EDIT: I've changed motor selection slightly and am also taking a bigger plunge by going with a suby trans, see Post #49. |
Britain Smith |
Nano Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,354 Joined: 27-February 03 From: Hillsboro, OR Member No.: 364 ![]() |
When you say motor mount arms...are you talking about the engine cradle thing they sale?
Which Kennedy set-up did you go for? -Britain |
sawtooth |
When you say motor mount arms...are you talking about the engine cradle thing they sale? Which Kennedy set-up did you go for? -Britain It's this mount from Small Car Performance, but they sold me just the 2 arms that bolt up to the block, not the cross piece you see in the pic. I bolted these up to the block, and welded a piece of 2" angle at the front for the cross brace. This brace then sits on top and bolted to the stock 914 engine mount bar. I stole this idea from Amensen. But, I didn't cut lower notches like he did. I let the bar sit on top which gives enough clearance below that I don't have to modify the oil pan which is a big plus for me. Only down side to the engine sitting up that high is that there isn't enough room for the intake hose between the trunk. I'm planning on A/C at some point so I'm not flipping the intake manifold 180 like some do. I'll end up modifying the trunk slightly to make room for an intake hose. I just have the standard kennedy adapter with the stock 200mm pressure plate size. I plan on using that for a while and then converting to a suby trans later. |
Lo-Fi Version | Time is now: 19th April 2025 - 03:41 PM |
