Full flow oil system, is this bs or what? |
kdfoust |
Mar 21 2004, 03:47 AM
Senior Member Group: Members Posts: 694 Joined: 2-January 03 From: Riverside Member No.: 71 Region Association: Southern California |
I'll be getting my case back from RIMCO pretty soon and I'm thinking about the oil system. I'm planning to run a 30mm Schradeck (sp?) pump. I've read a number of threads about "full flow" oiling for TIV engines and I guess I don't get it.
For full flow on a TIV you do what? Plug or modify the oil filter bypass valve that I've circled below? Then what? Modify the oil pressure relief valve (new spring I guess) to accomodate higher pressure? Then what? At what pressure does the stock cooler blow open like a pan of Pop-Magic pop corn? TIA, Kevin Attached image(s) |
Mark Henry |
Mar 21 2004, 08:05 AM
Oh boy…you can get several different opinions on this one…
“I” would plug the filter by-pass and put a T1 (single relief, heavier) spring in for the pressure relief valve. This I have done with no ill effects. On my new engine I’m going to stretch the other relief spring (small one by the lifters) a ¼” or so. I’m also planning on reaming and match porting my oil galleys as much as I can. |
Lo-Fi Version | Time is now: 20th October 2024 - 06:54 AM |
